976291 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 13, 2026, 05:41 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Tuf Neck stem dismantling
Author Topic: Tuf Neck stem dismantling  (Read 2172 times)
burnaliser
« on: September 25, 2007, 04:11 PM »
Is it possible to take a Tuf Neck stem fully to bits?
And if so, how do i get the main shaft thingy off the bottom block of the stem? ???
Re: Tuf Neck stem dismantling
« Reply #1 on: September 25, 2007, 06:14 PM »
Yes you can dismantle them, ideally you need a bearing press type machine to push the shaft out as it won't damage the stem that way  :daumenhoch:
Offline Rombloke
  • do one
« Reply #2 on: September 25, 2007, 06:55 PM »
yes you can, but i gotta ask, why would you want to.
Dave
haro, how do you do
« Reply #3 on: September 25, 2007, 06:57 PM »
Dave
Re-Anodising or super polish?
I stripped mine to get it re-anodised and it's come up a treat  :daumenhoch:
« Reply #4 on: September 25, 2007, 09:47 PM »
Dave
Any Photo's  ???
Offline Steve P
« Reply #5 on: September 25, 2007, 10:00 PM »
I find resto work easier with no quill. I've recently finished this one ... Marty will remember this stem  :daumenhoch:
Steve
« Reply #6 on: September 25, 2007, 10:12 PM »
Dave
Any Photo's  ???
Will sort some tomorrow  :daumenhoch:
« Reply #7 on: September 25, 2007, 10:41 PM »
i tapped my one out
and was super loose
when i refitted it
had to araldite it in to stop it moving
burnaliser
« Reply #8 on: September 26, 2007, 02:39 PM »
Thanks for the tips, I wanted to get it powdered, so think I'll just leave the stem attached if I might end up with problems later...
« Reply #9 on: September 27, 2007, 08:08 PM »
I don't think you will have problems with it but tbh I would not get it powdered they look better in the raw of anodised  :daumenhoch:
