976293 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 14, 2026, 10:25 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Oxalic Bath
Author Topic: Oxalic Bath  (Read 2229 times)
Oxalic Bath
« on: September 26, 2007, 02:11 PM »
Been reading about this and a bit concerned i'd mess things up, so need advice. Just bought a mongoose survivor and parts could do with being cleaned up or rust removed. I understand from what I've read that a Oxalic bath will sort out the parts and bring them back to a very good condition.
Where do you buy this stuff and has anyone does this before?
Any advice given would be useful.
Thanks in advance,
Riz ;)
Offline brass monkey!
Re: Oxalic Bath
« Reply #1 on: September 26, 2007, 02:36 PM »
i'd say superbikeDan is the best person to talk to on this subject, he's a Pro on these topics !?
thesku11s
Re: Oxalic Bath
« Reply #2 on: October 01, 2007, 12:02 PM »
My local powder coaters do the acid bath & shot blasting for free.
they only Charge £20 for f&f too.
It might be more sensible to get out the yellow pages ;)
Re: Oxalic Bath
« Reply #3 on: October 01, 2007, 12:04 PM »
what are the results like though?  you may get it cheaper but are they as good as Dan?   :daumenhoch:
thesku11s
Re: Oxalic Bath
« Reply #4 on: October 01, 2007, 12:16 PM »
I didnt mean it would be better than dan, but a lot easier to find somewhere local usually than spending it all on couriers.
im sure theres a lot of workshops, maybe classic motorbike restorers? that would be up to the job.
Its nice to find good trades people locally.
Re: Oxalic Bath
« Reply #5 on: October 01, 2007, 12:18 PM »
i take you point mate  :daumenhoch:  always good to use local trades and produce when you can!  :daumenhoch:
Offline superbikedan
Re: Oxalic Bath
« Reply #6 on: October 01, 2007, 12:30 PM »
mattriz  can you post a pic so i can have a look :)
slightly confused as to the rust,  is it surface rust or has it broke through
the chrome or paint :daumenhoch:
munners
Re: Oxalic Bath
« Reply #7 on: October 01, 2007, 12:34 PM »
Easy peesey!
Buy a builders plastering bath - about £20.
There is a link on here somewhere where you can buy Oxalic acid in crystal form. It comes in a tub of about 1kg if i remember. Fill the bath with water and then put the crystyals in. Give it a stir and then sink the f+f. Leave for 2 days and presto.
Give it a clean with hot sopay water and then a light polish with Autosolvo and it comes out like new.
No good for bad pitting though.
wildwood1971
Re: Oxalic Bath
« Reply #8 on: October 01, 2007, 12:50 PM »
make sure you protect the frame after Oxalic acid treat meant tho - it needs to be protected inside and out or it will accelerate the rusting process  :daumenhoch:
Re: Oxalic Bath
« Reply #9 on: October 01, 2007, 01:28 PM »
you know what i was going to post something regards the future rusting on the frame due to being submerged in water and acid?  surely a steel frame (let alone a 20 year old one) shouldn't really be submerged in water as you're never going to dry out the inside properly? therefore rust from the inside out!  :-\
Re: Oxalic Bath
« Reply #10 on: October 01, 2007, 02:01 PM »
tbh  it would takes years and i mean tens of years for the frame to rust from the inside out
basicaly  when you submerge the frame in stripper or acid a powder coater would dry the frame of
before coating then it's dried again after painting, so the rust on the outside is now sealed and the
inside has just been cleaned,  also bikes are left mainly indoors so are in a dry enviroment
only leaving it out doors for years on end would it rust ;)
Re: Oxalic Bath
« Reply #11 on: October 01, 2007, 02:13 PM »
cool!  that's cleared that one up then.....cheers Dan  :daumenhoch:
wildwood1971
Re: Oxalic Bath
« Reply #12 on: October 01, 2007, 02:20 PM »
Thanks for clearing that up Dan  :daumenhoch:
