976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 03, 2026, 11:02 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  who owns a proclass cruiser? info added + PICS
Author Topic: who owns a proclass cruiser? info added + PICS  (Read 3324 times)
login_user
« on: September 30, 2007, 06:31 PM »
Gents, for those of you lucky to own a proclass cruiser, whats your serial number?
Thanks Mark
« Last Edit: October 03, 2007, 09:52 PM by login_user »
login_user
Re: who owns a proclass cruiser?
« Reply #1 on: October 02, 2007, 10:17 AM »
 :-\  no one? i know gmac does. Anyone else? I've got 2.  ;)
login_user
« Reply #2 on: October 02, 2007, 05:24 PM »
Just striped and weighed both my proclass cruiser frame and forks, Firstly the 84 frame weighs 4 1/2 lbs forks weigh just over 2lb Next the 85 frame weighs 5 1/2 lbs and the forks weigh just under 2lb
so basicly the 84 is built like a 20" proclass where as the 85 is built like a Cali.  :-\
Any one want to buy one?
will add pics later when the cameras charged.
Thanks Mark
Offline kdw712
Re: who owns a proclass cruiser? info added
« Reply #3 on: October 02, 2007, 05:27 PM »
mark whats the serial numbers on them ?
are the same format as regular sized gooses ?
cheers Kev
login_user
« Reply #4 on: October 02, 2007, 05:35 PM »
The 84 is stamped in the same place and is the same format as a proclass/supergoose, Where as the 85 is stamped and is in the same format as a cali.  :daumenhoch:
Offline kdw712
« Reply #5 on: October 02, 2007, 05:54 PM »
I have a trimoly 20" frame (orig decal still there)
and its stamped on the "C" section not the BB shell
never found a reason why that is or if its significant at all.
cheers Kev
login_user
« Reply #6 on: October 02, 2007, 05:58 PM »
Mongoose done some weird stuff sometimes,who knows why?
Offline kdw712
« Reply #7 on: October 02, 2007, 06:04 PM »
off topic i know
but over on vintage Ted Carl has done a 1975 goose with his amazing restro's skills (def worth a look if you can)
and theres a bit in one of the threads about the decals
and red to the front etc, but as skip hess put it
 i had bmxers and cheap labour doing that sort of work, quality control weren't high on the list
or words to that effect.  :D
cheers Kev
login_user
« Reply #8 on: October 02, 2007, 06:12 PM »
off topic i know
Soo True  :LolLolLolLol: you have to pay to be a member on vintage don't you?
Offline jimmyp
« Reply #9 on: October 02, 2007, 10:19 PM »
Get some pics up you fool  :LolLolLolLol:
All the later mongoose models where mostly like the uk supergoose tubing as it was lighter than the usa super  :-\ :'(
 :-[ :-\ :shocked: :'( :-[ ::) ??? :( >:( :D :2funny:
login_user
« Reply #10 on: October 03, 2007, 04:04 PM »
Same size tubes jim, just different wall thickness's, a good comparison is the 20" proclass(thin walled tubing and the supergoose3 (83 model) exactly the same frame geometry and tube sizes only with thicker walled tubing.  :daumenhoch:
login_user
« Reply #11 on: October 03, 2007, 09:51 PM »
Some pics,
Heres the forks 84 on the left 85 on the right
84 rear brake bridge
85 rear brake bridge
84 serial #
85 serial # oops didn't come out,but its on the b/b area
84 frame side view
85 side view
84 rear drop out thickness
85 rear drop out thickness
Both need a bloody good clean and polish.  :daumenhoch:
Re: who owns a proclass cruiser? info added + PICS
« Reply #12 on: October 03, 2007, 10:41 PM »
Is the rear end longer on the 85 ? .
Brake bridges at different lengths or further up/down rear seat stays  ???
login_user
« Reply #13 on: October 03, 2007, 10:49 PM »
Same postion,its just because the one on the 85 is raised and has  a shape to it.
« Reply #14 on: October 03, 2007, 10:53 PM »
Is centre of BB to start of dropout the same ?
login_user
« Reply #15 on: October 03, 2007, 11:03 PM »
it's very close, the top tube is lower on the 85, i will try and take a pic tomorrow with one laid over the other so you can see the differences, they are very close just a few degrees difference.  :daumenhoch:
Offline jimmyp
« Reply #16 on: October 04, 2007, 08:42 PM »
Same brake bridge as an 85-86 eric rupe model. Just looks like a change in models from 85 then ehh :daumenhoch:
login_user
« Reply #17 on: October 06, 2007, 09:09 PM »
Looks like it Jim, The 84 is the lighter and proberly better bike, where as the 85 is heavier and stronger.
Offline Steve P
« Reply #18 on: December 09, 2007, 12:56 PM »
Great thread Mark .. your pics prove very useful and now I see the differences between each frame set  :daumenhoch:
I'm looking forward to restoring that 84 now ... it'll keep me busy for a while but it's worth it  :D
Steve
