976293 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 14, 2026, 06:56 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  seat post removal
Author Topic: seat post removal  (Read 1606 times)
Offline sawzall
seat post removal
« on: October 08, 2007, 07:10 PM »
heres a few pics of how to remove a seat post if all else fails,i spent about 2 hours yesterday on a piller drill  :shocked: i used two drill bits,one that was slightly bigger than the inside diameter of the seat post,the second one was almost the same size as post, i made sure i used plenty of cutting compound and kept frame level............
heres the only bit of post that survived  >:D
Offline Del
  • Re-living my youth!
Re: seat post removal
« Reply #1 on: October 08, 2007, 07:28 PM »
a bit stuck then was it?  :LolLolLolLol:
« Reply #2 on: October 08, 2007, 07:42 PM »
Wow  :shocked: you done good not to drill through the side of the seat tube  :daumenhoch:
very well
« Reply #3 on: October 08, 2007, 08:56 PM »
Quality work  :daumenhoch:
« Reply #4 on: October 08, 2007, 09:39 PM »
Top work there :smitten:, hows the seat tube with out the seatpost in it? ::)
Offline sawzall
« Reply #5 on: October 09, 2007, 06:19 PM »
not two bad steve just got a bit of a gap to repair :shocked:
« Reply #6 on: October 09, 2007, 08:29 PM »
Look forward 2 seeing that repaired. ;) Top bombing. :daumenhoch:
motomagII
« Reply #7 on: October 10, 2007, 12:02 PM »
what frame is that nice neat brazing/welding is it curtis or mrd ???
