976294 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 16, 2026, 08:01 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  PK freshly anodised # NEW PICS ADDED Pg1 #
Author Topic: PK freshly anodised # NEW PICS ADDED Pg1 #  (Read 5473 times)
Re: PK freshly anodised!
« Reply #25 on: November 13, 2007, 11:00 PM »
That's looking very cool  :coolsmiley:
darkersomeday
« Reply #26 on: November 13, 2007, 11:11 PM »
that actually looks really cool :daumenhoch:
big pimpin :shocked:
looking forward to seeing this built :knuppel2:
darkslider
« Reply #27 on: November 13, 2007, 11:23 PM »
Very tasty work. Reckon he could fettle this up? I'm worried about the two tone effect! Like the Selector, and Madness though!
« Reply #28 on: November 13, 2007, 11:27 PM »
Its hard to re-anodise stems cos of the steel shaft: it will desolve in the anodising process. If the shaft comes away from the ally body (like a pro/tuff neck) then its do-able, but the fit might not be as good cos the process will change the hole size a little as it removes a tiny bit of material from the ally.
darkslider
« Reply #29 on: November 13, 2007, 11:44 PM »
Apparently the brute wedge doesn't remove! See Redline Proline II thread! Cheers Alex :daumenhoch:
customparts
« Reply #30 on: November 14, 2007, 10:08 AM »
the steel bar can be masked off with this tape we have got,  its acid proof so as long as the ali is anodisable then its ok with the bar in :daumenhoch:
CCA
Offline generallee
« Reply #31 on: November 14, 2007, 12:34 PM »
new pics added to to the top of this thread!
Frosty
« Reply #32 on: November 14, 2007, 12:37 PM »
What about inside the stem steel shaft, or are the parts not submerged in acid??
teamsano
« Reply #33 on: November 15, 2007, 09:49 PM »
CCA
that sounds like flannel.
frame looks nice, purple is a bit mtb tho.
Donker
« Reply #34 on: November 23, 2007, 03:28 PM »
CCA
it isnt flannel, it can be done. :Great_Britain:
pic1london
Re: PK freshly anodised # NEW PICS ADDED Pg1 #
« Reply #35 on: November 25, 2007, 12:57 AM »
Nice job there Steve...
Very good price too.
The quote I gave you a while back was for all the polishing & a 3 week turnaround door to door. Taking it there & back by hand no postage.... Just thought I needed to clear that up.
Re; the tape/redline stem question?
Yes it can be done.
Lead tape (for roofing) is the trick...Approx £100 a roll.
Plus you have to plug up the holes..
