976294 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 16, 2026, 05:16 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  HELP!!TIOGA H/SET PROB ON DP FIREBIRD F/S
Author Topic: HELP!!TIOGA H/SET PROB ON DP FIREBIRD F/S  (Read 1655 times)
Offline GTnumber1
« on: November 16, 2007, 06:20 PM »
Hi guys
picked up my DP FIREBIRD FREESTYLE FRAME & FORKS today from SUPER BIKE DAN who did n awsome job, HE D MAN!!!!!!!!!
My  MAJOR PROBLEM guys is tried fiting a NOS TIOGA MASTER DL headset and the bottom cup is to to small n wont fit its like a dick in a bowler hat. any suggestions guys.
                         CHEERS :daumenhoch:
Re: HELP!!TIOGA H/SET PROB ON DP FIREBIRD F/S
« Reply #1 on: November 16, 2007, 06:31 PM »
a pic would help, can't remember what the Master DL headset is all about.  The head tube isn't flared at all is it?
Offline GTnumber1
« Reply #2 on: November 16, 2007, 07:57 PM »
Frames ok. cant put any pics up at the mo. its the bootom cup it just falls into the tube as if it were for a smaller bike
« Reply #3 on: November 16, 2007, 08:07 PM »
I know there is a smaller headset than the 1 inch but can't imagine that you'd have different sized cups with the set have you checked that the top and bottom cups are the same diameter?  If they are then it will be the frame, maybe you could get a shim made up or use some trusty old electrical tape to get shim it out  :daumenhoch:.
« Reply #4 on: November 16, 2007, 08:07 PM »
If its 1" threaded, then both cups should be identical shouldn't they?  Perhaps there's a mix up in the headset packaging?
« Reply #5 on: November 19, 2007, 07:27 PM »
How did you get on with the headset?  Problem solved now?
