976294 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 16, 2026, 10:31 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  redline flite bearing shims where 2 buy ???
Author Topic: redline flite bearing shims where 2 buy ???  (Read 2353 times)
kowalski
« on: November 29, 2007, 03:59 PM »
ok after taking advise from everyone about n/s flite bearings i promptly bought some new ones size 6904, they fit over the spindle but have some play on them so i need the small 1mm metal shims to get them sitting flush,
 where for the love of mohamed do you buy buy them from  :-\
Re: redline flite bearing shims where 2 buy ???
« Reply #1 on: November 29, 2007, 08:05 PM »
Ask at your local good quality bike shop for 20mm shims, profile ones fit very nicely which i got from groove racing :daumenhoch:
kowalski
« Reply #2 on: November 29, 2007, 08:33 PM »
« Reply #3 on: November 29, 2007, 08:36 PM »
kowalski
« Reply #4 on: November 29, 2007, 08:40 PM »
are you sure these are what i want ? you know the bearings you sent me they had like an extra ring inside them to make the hole itself tighter but i fooked them trying to get them out  :'(
« Reply #5 on: November 29, 2007, 08:43 PM »
The bearings you got off me were 20mm, is your axle a redline flite axle or a proline one? Try freezing the bearings before fitting them, that usually gives a bit more clearance
« Reply #6 on: November 29, 2007, 08:49 PM »
You need a top hat shim to reduce the inside diameter of the bearing, no idea who sells them. I had the same issue a few year back, I ended up smashing my old bearing with a hammer to get at the shim and just re used that :-\
bof
« Reply #7 on: November 29, 2007, 09:15 PM »
custom riders do them look under BB spares  :daumenhoch:
kowalski
« Reply #8 on: November 29, 2007, 09:49 PM »
bof could you send me the link please mate i can't see them on there  :daumenhoch:
and boys thanks for the advise they are as ron says, but seem quite hard to find  :'(
bof
« Reply #9 on: November 29, 2007, 10:03 PM »
Im afraid its bad news they where in this section http://www.customriders.com/prodlist.asp?a=cat&parent=1001&cat=10&sort=3&pg=1
But they are no longer there I think they where called GBH adaptors to fit 19mm shaft into 20mm bearings. Give them a ring they may still have them on the shelf but not on the website. Good luck :daumenhoch:
« Reply #10 on: November 29, 2007, 10:14 PM »
Can of coke and tin snips  :daumenhoch:
Offline Gary72
« Reply #11 on: November 29, 2007, 11:07 PM »
I will probably get shot for this :2gunsfiring_v1:
I got some cranks with a frame and the bearings were rough, so thought no worries looked on the side of the old bearings for the number 6004, ordered 2 new bearings from ebay £3 delivered. found to be too tight on the spindle, so tried a bearing shop to see if it was my cheap bearings, but same with there's. This was on the saturday before the CIN ride. So here comes my bodge of the year, fitted a bolt into the end of the spindle, clamped it in my drill and set to work with a fine file on the spindle, kept trying bearings, once it got close swapped to wet and dry paper until spindle shiny and bearings just needing a slight tap with a hammer. Fitted  together with anti-seize compound.
JOB DONE.
kowalski
« Reply #12 on: November 30, 2007, 03:30 PM »
boys is there not a 19mm bearing i can buy for redline flites, ps gary that is quality i wish my problem was that way round im a legend with a sander  :idiot2:
« Reply #13 on: November 30, 2007, 03:34 PM »
I'll have a word with my mate who's got a machine shop, he might be able to knock something up, wont be until next week when I next see him though.
kowalski
« Reply #14 on: November 30, 2007, 04:06 PM »
marty that would be great ,
i am also on the case but any help would be gratefully accepted
thanks mate  :daumenhoch:
« Reply #15 on: November 30, 2007, 04:18 PM »
No problem, I think I might need a couple of them too  :daumenhoch:
