976294 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 16, 2026, 11:28 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Cassette hub maintence
Author Topic: Cassette hub maintence  (Read 2023 times)
Offline Gary72
« on: November 29, 2007, 10:53 PM »
Just taken my rear wheel off to change the tyre and was wondering if there is any regular maintence that should be done to the hub. I'm used to loose ball and cones so would clean and re-grease at this point.
Should I just leave alone or take the driver out and grease/oil; will it fall to pieces and dis-appear under the sofa :tickedoff:
Re: Cassette hub maintence
« Reply #1 on: November 29, 2007, 10:56 PM »
i always clean and light oil my driver gary
as grease makes the paws slip
Offline Gary72
« Reply #2 on: November 29, 2007, 10:59 PM »
Cheers, would 3in1 be ok.  or have shell 10-40 at work :LolLolLolLol:
« Reply #3 on: November 29, 2007, 11:01 PM »
yeah 3in 1 ok never tried other lol
Offline Gary72
« Reply #4 on: November 29, 2007, 11:09 PM »
p.s got grief today at work fitting the Khe tyre as it cost the same as the ones on my car :idiot2:
Offline Philbert
« Reply #5 on: November 29, 2007, 11:25 PM »
only a drop of oil though. too much and you'll be slipping the freehub when you power down
« Reply #6 on: November 29, 2007, 11:33 PM »
I greased my driver ... a tiny bit. It made it so nice and quiet. BUT it almost slips now. Not much, just now and again when you lean on the pedal, it clicks. I need to clean it out and OIL it.
Offline Gary72
« Reply #7 on: November 29, 2007, 11:34 PM »
Think I,ve had that happen a couple of times crank just seems to slip/drop an inch or so than catches and go's, hear a noise at the same time.
Offline Philbert
« Reply #8 on: November 29, 2007, 11:51 PM »
that'll do it!
the best option i've found is to give it a quick spray with a teflon spray, gt85 or tf2. as it goes tacky and won't run away. but won't goo up the internals. my odyssey cassette was last done about 4 months ago and hasn't slipped once. it works a treat!
Offline Gary72
« Reply #9 on: November 30, 2007, 12:34 PM »
Used Snap-On air oil, nice and light lubed and quick wipe. Will see how it goes at the weekend.
« Reply #10 on: November 30, 2007, 01:48 PM »
Good stuff lads, i was going to post the same thing as mines been slipping and i need to give it a clean up. i'll have to nick a can of teflon spray from work  :daumenhoch:
« Reply #11 on: November 30, 2007, 09:12 PM »
Yip.  My Macneil hub put me over the bars on one of my first rides out on it.
'This seems nice and quiet..... mmm....smooth........'  WALLOP!!!!  Straight to head....   :(
Anyhoo, the pawls and hub internals need to be spotless, (any grease or muck makes the pawls stick down, which is yer slip....) and a drop of light oil on each pawl will do it.  There is a reason why modern hubs are so damn noisy - I hate that.  Grrr.......
« Reply #12 on: December 02, 2007, 08:36 AM »
Degrease and apply a Pawl oil, Mavic do one, any road bike shop should have some  :daumenhoch:
