976294 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 16, 2026, 05:11 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Couldn't believe it actually worked! :)
Author Topic: Couldn't believe it actually worked! :)  (Read 1894 times)
« on: December 10, 2007, 02:58 PM »
Lads, bought some Haro copy bars from Jon, these were described as rusty and in need of a re-chrome and when they arrived they weren't in good shape which I knew anyway. I don't have an acid  bath as yet but thought i'll try something I read about on the web. I took a 1-metre length of kitchen foil and scrunched it up into a ball, then poured a very small glass of coca-cola (one for me also with JD in it  ;) ) and dipped it into the coke and started rubbing the bars. No lie, about 15 mins later and not a lot of elbow grease to be honest, here is the result. It basically took off all the rust easily and after a quick once over with Brasso wading, the result is very good, no need for a re-chrome at all. Very happy. What do you reckon? Just need some Bob Haro Vector decals now...   8)
Matt  :daumenhoch:
Here is Jon's piccy of the bars before:
And here's the bars after i've had a good go at them:
munners
Re: Couldn't believe it actually worked! :)
« Reply #1 on: December 10, 2007, 03:05 PM »
Wicked! Always like new ways. Cheaper than oxalic! looks great mate.
Offline BrianP
« Reply #2 on: December 10, 2007, 03:08 PM »
wow!
nice one, they look well now.
Brian :daumenhoch:
Offline kdw712
« Reply #3 on: December 10, 2007, 03:21 PM »
i've used the scrunchie foil truck before
not tried it with coke
those results speak for themselves - amazing ! :daumenhoch:
cheers Kev
« Reply #4 on: December 10, 2007, 03:41 PM »
Thanks lads, yeah it really has amazed me.... just shows you what coca-cola can do to our stomach's eh? ;)
munners
« Reply #5 on: December 10, 2007, 03:42 PM »
Ive got loads of rust in my belly so it should work wonders.
« Reply #6 on: December 10, 2007, 03:45 PM »
Haha :D Because it worked so well I dug out the kuwi from the loft and had a look at that, only thing is that the chrome really has pealed on that :( so can't do my foil trick on it unfortunately... will try it on my survivor Ammaco though that's for sure as it really did work well.
Offline bodamus
« Reply #7 on: December 10, 2007, 04:08 PM »
Wow great job I shall be trying that at the weekend.
bodamus.
Offline kuwahero
    • Western Titans
« Reply #8 on: December 10, 2007, 04:16 PM »
Bacofoil & Coke. Make mine a double. Lol
Great result Matt. I'm going to give it a try tonight.
p.s. Take it you got the decals ok
Marc
« Reply #9 on: December 10, 2007, 04:24 PM »
Marc hi mate yep got them thanks a lot, top stuff... also Ian, you should give it a go mate it really does work... also pour one for yourself and stick a large vodka in there ;)
Dhillon
« Reply #10 on: December 10, 2007, 06:09 PM »
Cheers for the tip Matt!
Damn good results on the bars
Offline bmxmatt1974
« Reply #11 on: December 10, 2007, 06:11 PM »
cheers for the tip, will be trying that
« Reply #12 on: December 10, 2007, 06:24 PM »
Try it lads, it really works... also you hardly use any coke too... I think I used not even a quarter of a small whiskey glass full to do them bars, so to do a whole frame you'll probably use a glass or two. Its certainly a cheap way of removing rust from chrome that's for sure. Then afterwards either use autosol or something similar to buff them up to a bling finish ;)
