PINK SEAT DYEING HELP NEEDED.
theRuler:
you should ask her if she prefers pink or brown
dordymush:
i'll let you know what she says then :santa_grin:.
OldSchoolBikesTx:
I was always taught not to put salt while dying as the salt locks in the fabric (sealing it). I suggest bioling the seat with the dye solution then soak the seat afterwards in a cold/clean/very salty water solution. If you use salt during the dying process, the seat will only get as dark as the salt will let it before the salt starts to react to the fabric. Hope you haven't done it yet...
dordymush:
nope not yet. i've still not found a dye thats darker than the seat already is :(.
theRuler:
i like the idea of a furry pink covering.
Navigation
[0] Message Index
[*] Previous page
Go to full version
