976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 17, 2026, 04:33 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Freewheel removal – which tool?
Author Topic: Freewheel removal – which tool?  (Read 1200 times)
Stevo
« on: January 07, 2008, 08:48 PM »
Guys, I would like remove this freewheel from a Haro Sport 06. Anyone know the manufacturer/model of the tool needed.
A supplier would be helpful too. Cheers
Re: Freewheel removal – which tool?
« Reply #1 on: January 07, 2008, 09:01 PM »
It's a screw on lock ring, you should be able to get it off using a flat bladed screwdriver and a hammer, tap it anti-clockwise to undo.  You can see the the mark close to the word "LOCK" where it's been tightened up using the same method  :daumenhoch:.
THIRSTYKIRSTY
« Reply #2 on: January 07, 2008, 09:02 PM »
SAME AS ME CRUISER
ALL I DO IS GET A GOOD SCREW DRIVER
LEAVE WHEEL ON BIKE AND GET SOMEONE TO PUT FOOT ON PEDAL AND JUST CLOUT IT ANTICLOCKWISE
DOES THE JOB A TREAT
RUSS :crazy2:
Stevo
« Reply #3 on: January 07, 2008, 09:12 PM »
Thanks guys, I did try it with a screw driver but it wouldn't budge. I will try again as it seems this is correct way to remove it. Cheers
subversion
« Reply #4 on: January 07, 2008, 10:28 PM »
get yourself a C SPANNER from your local cycle/HW store :police: this will avoid damaging the lock ring....
2020mad
« Reply #5 on: January 07, 2008, 10:57 PM »
Get a bigger hammer stevo  :daumenhoch:
