jive tentacles
<< < (2/2)
SaMAlex:
I used black Jive grips for much of the early 90s. They were pretty much the same as the ones you can buy now. I think the end plug was different. I think on the early ones the grip went over the end of the bar and had a little bar plug that youd put on under the grip. There are a few different grip patterns. Handles were the ones I used to use.
On a NS tip, United Bikes have a new grip called the UJive. Very similar to Jive grips, very thin and feel great. Ive just fitted a pair to my bike. Here is the 4Down info on them:
http://www.4downdistribution.com/pd/gr/unitedujivegrips.html
snav69:
Here's some of those Jive Handles  ;)
http://www.extreme-direct.co.uk/products-JIVE-HANDLES-GRIPS_8541.htm
 :coolsmiley:
SaMAlex:
Yep, they have got the "over the top" bar end, not the "under the grip" ones. Other than that I think they are the same.
zed4130:
thanks alex i kmew you would know about these midschool things  ;) and paul the black pnes are spot on, extreme direct on ebay are only showing the red and blue ones, but the vlack ones are spot on, thanks mate  :4_17_5:
snav69:
No worries Paul  :daumenhoch:
 :coolsmiley:
Navigation
[0] Message Index
[*] Previous page
Go to full version
