976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 18, 2026, 08:43 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  removing chrome help
Author Topic: removing chrome help  (Read 2038 times)
therock
« on: January 27, 2008, 08:16 AM »
whats the best way to get chrome plating off . any one no of any were that does sand blasting in the wigan area that ll do it. :daumenhoch:
Re: removing chrome help
« Reply #1 on: January 27, 2008, 08:19 AM »
take it to a place that does chroming if you can ,they will reverse the chroming procedure.
and its cheap and quick.
Offline Rombloke
  • do one
« Reply #2 on: January 27, 2008, 10:43 AM »
do not get the chrome blasted off, you will end up with a fu'cked frame, take it to the chromers, where they use a process which is the reverse of the plating process to get it off.....
again............DO NOT BLAST
it'll cost ya 15 quid or so to get it chemically stripped.
Dave
haro, how do you do
« Reply #3 on: January 27, 2008, 11:04 AM »
Why not blast  ??? what does it do  :-\
I had one blasted & it was ok & is it ok to blast Painted or powder  ???
« Reply #4 on: January 27, 2008, 01:22 PM »
If it is stripped using the wrong media it can leave the frame pitted all over which makes it very hard to get a good finish.  It's always best to get it stripped at a chromers as they use a electro-chemical process which unless they fook it up completely (remember that National Pro?) leaves no damage on the metal  :daumenhoch:.
« Reply #5 on: January 27, 2008, 04:06 PM »
So is it ok to blast powder  ???
« Reply #6 on: January 27, 2008, 05:50 PM »
I think it depends on what they use to blast it, I understand from my mate who does powder coating that "media blasting" is the best way, i think it's a less agressive material so doesn't damage the metal :daumenhoch:
« Reply #7 on: January 27, 2008, 06:35 PM »
Thanks Iv got one where I can't get the paint off  ::)
therock
« Reply #8 on: January 27, 2008, 07:07 PM »
thanks for the advice chaps.  :daumenhoch:
Offline PHIPPSIO
« Reply #9 on: January 27, 2008, 07:34 PM »
I just stripped a frame that was painted, but previously media blasted with walnut shell, barely any damage to the steel at all, thats the way forward :daumenhoch:
lcfc
« Reply #10 on: January 27, 2008, 09:03 PM »
  Thats nutts  ;D
« Reply #11 on: January 27, 2008, 09:07 PM »
ive blasted a frame using glass beads
as they do gearbox casings as not to damage em
bloke opp me at work has it but a frame just fits
and ya have to keep taking it out to do different angles lol
plus the more he uses it the finer the glass gets
therock
« Reply #12 on: January 29, 2008, 06:53 AM »
ok so were do i get it chemically removed , is there any were that radsters usuakky use that i can post it off too . cheers again
