976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 18, 2026, 09:56 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  removing grips
Author Topic: removing grips  (Read 1754 times)
brettnai
removing grips
« on: January 30, 2008, 07:45 PM »
I need to remove some grips and if poss keep them intact to refit after I've put some levers on.
Is there an easy way of doing this?
Re: removing grips
« Reply #1 on: January 30, 2008, 07:47 PM »
Slide a screw driver between the grip and the bars and spray WD40 in the gap, few twists and hey presto  :daumenhoch:
Re: removing grips
« Reply #2 on: January 30, 2008, 07:47 PM »
pm sent
series.1.rs.turbo
Re: removing grips
« Reply #3 on: January 30, 2008, 07:48 PM »
Or.... a bit of butter on a butter knife  :daumenhoch:
Offline brass monkey!
Re: removing grips
« Reply #4 on: January 30, 2008, 08:15 PM »
exactly !  :)
80sdave
Re: removing grips
« Reply #5 on: January 31, 2008, 07:46 AM »
Or use a pump with a thin nozzle while blocking any holes on the oppisite grip works a treat and leaves no residue on your grips so they dont slide off when your flying down the offy.  :daumenhoch:
evamedia
Re: removing grips
« Reply #6 on: January 31, 2008, 08:24 AM »
hairspray. the cheaper the better
Offline Gary72
Re: removing grips
« Reply #7 on: January 31, 2008, 10:20 AM »
WD40 with a straw in the nozzle, squirt,twist. tressemme heat defence spray for fitting.
brettnai
Re: removing grips
« Reply #8 on: January 31, 2008, 04:11 PM »
cheers guys!
all sorted!
