976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 19, 2026, 12:43 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  pitbull and posy seat clamp setup
Author Topic: pitbull and posy seat clamp setup  (Read 1622 times)
brettnai
« on: January 31, 2008, 04:16 PM »
Does anyone have a picture of  posy-stop seat clamp set up with a pitbull brake.
Because my Bully doesn't have a brake bridge as such its proving a bit tricky.
I've put the seat clamp on but the bit that hangs off it and guides the cable is too long, it over laps the bit that comes off from the pitbull (the bit with the adjuster on). If I'm using a posy do I need that bit? If I take it off I wont have an ajuster.
If that doesn't make sense I'll take a pic
brettnai
Re: pitbull and posy seat clamp setup
« Reply #1 on: January 31, 2008, 05:18 PM »
anyone?
« Reply #2 on: January 31, 2008, 05:23 PM »
on my bully i had the same issue
it did fit in the end, but it was really tight and fiddly
tbh it was such a pain in the arse to set up. and the brake's woeful performance didn't really warrant the fannyarsing around it too setting it up either.
post a pic. it may be that you need to run a side pull
either brake choice aint gonna be giving you massive skids
unless you count the ones in your grippers as you head towards a busy road with the back brake on full chat, but not slowing you down ;)
Offline kdw712
« Reply #3 on: January 31, 2008, 05:24 PM »
heres my pitbull posi stop on my free agent
cheers Kev
brettnai
« Reply #4 on: January 31, 2008, 06:05 PM »
brilliant! thats what I needed to see!
so you didnt use the adjuster that came with the pitbull and just used the posy to guide the cable instead?
B
« Reply #5 on: January 31, 2008, 06:27 PM »
yes brettnai  like in the piccy
brettnai
« Reply #6 on: January 31, 2008, 06:29 PM »
like this... sweet
« Last Edit: January 31, 2008, 06:31 PM by brettnai »
Offline kdw712
« Reply #7 on: January 31, 2008, 08:44 PM »
yeah its one or the other
i think the posi clamps look nicer me self
so i went that route
but with the standard thing you get a spring don't you?
which would def help the cam go back into place
cheers Kev
