976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 19, 2026, 07:51 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Dyeing Tuffs again
Author Topic: Dyeing Tuffs again  (Read 1947 times)
80sdave
Dyeing Tuffs again
« on: February 05, 2008, 03:03 PM »
Can anyone tell me if you have to use cold water dye when doing tuffs or does the machine stuff work in a tubb of water ?
munners
Re: Dyeing Tuffs again
« Reply #1 on: February 05, 2008, 03:04 PM »
I did some once and used cold. Worked fine.
2020mad
« Reply #2 on: February 05, 2008, 03:13 PM »
I would always use multi purpose dye, used cold water dye by mistake once, wheels fooked.
80sdave
« Reply #3 on: February 05, 2008, 05:17 PM »
Cheers guys :daumenhoch:
mark 2
« Reply #4 on: February 09, 2008, 12:07 AM »
What went wrong Martin? I'm due to do some, let me learn from your mistake if you don't mind ;)
« Reply #5 on: February 09, 2008, 12:11 AM »
Better off with hot water and a good amount of salt.  I got one of those big garden bucket thingys from B&Q and filled half hot tap water and half boiled in a pan on the stove to do mine - worked a treat.  I also left them in there for a day or so but if you do that remember to stir the water frequently as the dye "clumps" and you get spots of intense colour forming on the wheels; not so bad on black but a nightmare on yellow  :LolLolLolLol:.
2020mad
« Reply #6 on: February 09, 2008, 12:36 AM »
cold water dye left them patchy and uneven in colour, only thing i can do now is dye them black using multi purpose.
« Reply #7 on: February 09, 2008, 12:48 AM »
Martin, what colour were they and are you sure they cannot be corrected?
djdane
« Reply #8 on: February 09, 2008, 06:59 AM »
WHat brand of dye did you use? Over here in the states I used rit to dye quite a few sets. I always used boiling water with loads of salt and I also used one of those short metal tubs that resemble a trash can but I actually put it right on top of my stove in the kitchen. Imagine the looks I got when the missus came home!!!! :LolLolLolLol: Either way, they make a dye remover incase the job doesnt come out right. I had to use it once. 2 jugs per wheel and they came out whiye as can be from a dark orange color. I was going for a nice yellow but they dye will darken pretty quickly if you don't watch it and well it was baseball season hahaha. Pm me if anyone needs more indepth help as I have done loads of these as well as bleaching etc.
 Dan
