976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 19, 2026, 02:31 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Greasing up
Author Topic: Greasing up  (Read 1303 times)
dannywhiteley
Greasing up
« on: February 16, 2008, 09:05 AM »
When you build a show/display bike, do you bother with greasing up the BB and headset?  Seems like a lot of unecessary mess to me if it aint going to be ridden.
Also a silly question (but im still a novice).  Which way do the ball races sit in the BB?  Do the bearings rotate against the BB cup or the crank?
subversion
Re: Greasing up
« Reply #1 on: February 16, 2008, 01:06 PM »
If you take a loose ball bearing race in the cage & place it flat side down on the table like this:
then put the BB cup over it, covering it - that is the correct fitment :daumenhoch:
Same for headsets too...
The bearings rotate against both the Cups & the Crank races.
Re: Greasing up
« Reply #2 on: February 16, 2008, 07:37 PM »
I usually grease them up but maybe that's just me  :-\
Re: Greasing up
« Reply #3 on: February 16, 2008, 10:04 PM »
Grease it, even if it aint ridden, that way, when you missus pisses/pours something on it when you are not in, it wont rust the moving parts  :daumenhoch:
scooby74
Re: Greasing up
« Reply #4 on: February 16, 2008, 11:07 PM »
grease it up and ride it  :daumenhoch:
dannywhiteley
Re: Greasing up
« Reply #5 on: February 17, 2008, 09:54 AM »
Cheers for the info, I had the ball races in correctly, just checking :daumenhoch:
And I will grease up afterall, I need to swap the cranks so will do it then.  Not going to be ridden far, but it will protect the parts for if it is ever ridden.
