976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 19, 2026, 09:32 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Powder coat question for the Don
Author Topic: Powder coat question for the Don  (Read 1434 times)
muttley
« on: February 22, 2008, 08:06 AM »
If you have a frame repair IE dent repair, i suppose its done using filler, but my my query is if you then have the frame powdercoated does that area still get coated or as its not metal will it not adhere  ???
Ross.
Offline superbikedan
Re: Powder coat question for the Don
« Reply #1 on: February 22, 2008, 09:56 AM »
ross, you can't powder over body filler, what happens is that when the frame reaches
180degrees in heat in the oven,  the filler goes soft and starts to bubble, :daumenhoch:
Trev
« Reply #2 on: February 22, 2008, 09:59 AM »
looks like you're stuck with your spine trophy then Ross....  :P
muttley
« Reply #3 on: February 22, 2008, 10:05 AM »
DOH!!!!
Cant you turn the oven down a bit  :LolLolLolLol:
Offline sawzall
« Reply #4 on: February 22, 2008, 05:58 PM »
is it possible to powder over lead (body solder) ??? if not we have a tool at work that you can reverse pull dents out,most body shops should have one,i have done a couple of frames and bars with it with good results ;)
« Reply #5 on: February 22, 2008, 06:48 PM »
yeah ya need the weld on dent puller ross
