976295 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 20, 2026, 11:57 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  How to rattle can spray a f/f.. what do i need?
Author Topic: How to rattle can spray a f/f.. what do i need?  (Read 1939 times)
scary_leary
« on: March 06, 2008, 06:54 PM »
Looking at painting my pro racer myself..in plain white.
Can someone please post a quick n easy guide for a decent finish.
Re: How to rattle can spray a f/f.. what do i need?
« Reply #1 on: March 06, 2008, 07:19 PM »
yeah superbikedon
scary_leary
« Reply #2 on: March 06, 2008, 07:26 PM »
lol.. powders sooo last year
dodgy hung in the garage covered in dust fooked up runny paint finishes are back.. :daumenhoch:
« Reply #3 on: March 06, 2008, 07:29 PM »
just get dan to put it out side whilst wet lol
i just heat the parts up with a heat gun then use rattle cans from carrs paint shop
Offline sawzall
« Reply #4 on: March 06, 2008, 07:31 PM »
remove old paint with paint stripper then sand down with 500-600,then degrease and a light dusting of etch primer,2 or 3 coats of high build primer wet flat with 800 -1000 wet and dry,degrease again then spray 1 light coat and finish with a couple of wet coats ;)
« Reply #5 on: March 06, 2008, 07:40 PM »
Dan wet sprays too  :LolLolLolLol:
adeshere
« Reply #6 on: March 06, 2008, 07:43 PM »
Warmth :-)
Dont do it when its damp outside as it just wont harden properly
« Reply #7 on: March 06, 2008, 08:06 PM »
put the cans in hottish water.
its all in the sanding. you can spray any old shit. if you cut the paint right, it will be mirror.
adeshere
« Reply #8 on: March 06, 2008, 08:33 PM »
Also clear lacque to finish
scary_leary
« Reply #9 on: March 06, 2008, 09:18 PM »
cheers Phil
sounds pricey and hard work  :LolLolLolLol:
« Reply #10 on: March 06, 2008, 09:26 PM »
not pricey,but it is hard work.
Offline superbikedan
« Reply #11 on: March 06, 2008, 09:45 PM »
 :idiot2:  ;D is that some kind of old pre war type finish, fasinating :shocked:  no seriously, good luck with it,
it's all in the prep, so one tip, dont worry how the primer looks, if the frames pited or small dings, flood it on then
flat it off following the shape of the tubes, it will come out perfect :daumenhoch:
