976296 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 20, 2026, 10:30 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  crank question please
Author Topic: crank question please  (Read 1251 times)
motomagII
« on: March 20, 2008, 10:47 AM »
anyone know what diameter the axle is for mid school fishbone 3 piece crank please
HEYWOOD BMX
Re: crank question please
« Reply #1 on: March 20, 2008, 11:12 AM »
 :) Not sure,but think they were 20mm?
perry
« Reply #2 on: March 20, 2008, 11:29 AM »
dont know but while i clicked on this im reading a 96 issue of ride and they are in new stuff  :2funny:
"from the makers of the excellent ufo gyro system comes a set of three piece chromoly cranks . in terms of tubing used for the crank arms , these are beefier than comparable american-made 3pc cranks - the tubing used for the arms is heat treated 4130 cromoly ( theyre also heat treated after welding ) , the wall thickness of the tubing is 1.6mm and both ends are pierced for strength . the axle is also heat treated cromoly and splined for the crank arms . the kit comes with all the spacers and washers youll ever need , bolts to keep everything tight and a set of sealed precision bearing cartridges . the cranks will fit all sizes of chainwheels . all in , they look dead beefy and given all the facts theyre plenty strong - and the price is right , £169.99 for the set . well be testing some soon "
garethgeezer
« Reply #3 on: March 20, 2008, 12:57 PM »
Probably 20mm at the bearings, reducing to 19mm where the splines are (19mm sprocket size too).
HEYWOOD BMX
« Reply #4 on: March 20, 2008, 01:14 PM »
 :) The earlier Gusset cranks are like that-20mm at the bearing part,regular 19mm at the axle.
liverman666
« Reply #5 on: March 20, 2008, 06:43 PM »
Yep,spot on.20mm at the bearings,19mm at the splines.I`m running a set of these on my `84 Performer,they seem pretty good.............
