976296 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 21, 2026, 04:11 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  wheel building problems
Author Topic: wheel building problems  (Read 2128 times)
gareth1978
« on: March 27, 2008, 04:43 PM »
bought some rims, hubs and spokes
the rims are ukai 20 x 175 and the hubs are suzue
just wondered if i have the correct size spokes and if they are different sizes on the back from the front
as ive tried to build them and the spokes became to short and i was unable to lacse the rear wheel
the spokes are14 x184 mm
any help would be appreciated
« Last Edit: March 27, 2008, 04:56 PM by BevoBobby »
HEYWOOD BMX
Re: wheel building problems
« Reply #1 on: March 27, 2008, 04:57 PM »
 :) Large or small flange?
gareth1978
« Reply #2 on: March 27, 2008, 05:00 PM »
small flange
etriedes
« Reply #3 on: March 27, 2008, 05:56 PM »
i think you need 194mm with small flange ...
Offline se-bmxer
« Reply #4 on: March 27, 2008, 06:17 PM »
184mm should be fine if the nipples are long reach, you should have no problem with the rear as usually suzue rear flange hubs are slightly bigger than
the front, you might want to make sure you are lacing it 3 cross and not 4 cross as it will be short using 4 cross lacing pattern.
184mm with long reach nipples using suzue small flange hubs use 3 cross lacing pattern
194mm with long or short reach nipples using suzue small flange hubs use 4 cross lacing pattern
Hope that helps
gareth1978
« Reply #5 on: March 27, 2008, 06:38 PM »
when i tried lacing the rear wheel one side was fine but on the other side the last four spokes just would not reach the hub
and ive read every fookin tip and still no luck
Offline se-bmxer
« Reply #6 on: March 27, 2008, 06:47 PM »
is the one side that you laced 3 cross? and are the nipples long to give you an idea long reach nipples are 20mm long
also take a photo and post it
gareth1978
« Reply #7 on: March 27, 2008, 07:25 PM »
yes one side is laced up 3 across
ive striped the wheel in fustration but heres a pic of the nipple
http://i258.photobucket.com/albums/hh265/bevobobby/IMAGE_108.jpg
Offline se-bmxer
« Reply #8 on: March 27, 2008, 07:35 PM »
uummm  unusual they should be fine, have you measure the spokes to make sure there 184mm
as i've built loads of Ukai's with suzue small flange hubs using 184mm spokes but they are tight
to do. 194mm are the prefered choice
gareth1978
« Reply #9 on: March 27, 2008, 07:39 PM »
could i lace them up two across
Offline se-bmxer
« Reply #10 on: March 27, 2008, 07:45 PM »
Not if you are going to ride it, i only 2 cross on skinny wheels
