976301 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 29, 2026, 10:12 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Fitting Grips
Author Topic: Fitting Grips  (Read 2223 times)
lodge
Fitting Grips
« on: March 27, 2008, 05:00 PM »
A while ago someone posted on here a method for fitting grips, basically you place cable ties in the grip and then slide it on making sure the ties are fairly equally spaced around the bars, they go on easy as there's alot less friction, when there on you pull out the ties.
Never had my grips so tight untill I used this method.
So just wanted to say thanks to who ever posted the tip as nowt worse than grips that are slipping all ower the place and are stretched because you been wrestling wid em to get them on!
wildwood1971
Re: Fitting Grips
« Reply #1 on: March 27, 2008, 05:04 PM »
or spray inside of grip with gt85 / wd40  :daumenhoch:
HEYWOOD BMX
Re: Fitting Grips
« Reply #2 on: March 27, 2008, 05:11 PM »
Used this method a few hours ago.Grips are now stuck good`proper!
macky
Re: Fitting Grips
« Reply #3 on: March 27, 2008, 05:13 PM »
A mate of mine use's Hairspray!! swear's by it!!
grips slide on nice... couple of min's and they stick real nice!!
not used it myself yet... but he know's his stuff!!  :daumenhoch:
Re: Fitting Grips
« Reply #4 on: March 27, 2008, 05:37 PM »
ive always used hairspray, 15mins n stuck like fook, they come back off easy too when need be
Re: Fitting Grips
« Reply #5 on: March 27, 2008, 05:37 PM »
yep WD40 or Hairspray sticks em like poop to a blanket.......also in reverse if you spray WD40 under a grip and twist it comes off like a treet too  :daumenhoch:
jackel
Re: Fitting Grips
« Reply #6 on: March 27, 2008, 06:13 PM »
i use deoderant when it dries there on great :)
HEYWOOD BMX
Re: Fitting Grips
« Reply #7 on: March 27, 2008, 06:25 PM »
 Mmmmmmmm! Lynx choccy scented grips!
jackel
Re: Fitting Grips
« Reply #8 on: March 27, 2008, 06:26 PM »
lol just dont get to close to the women :)
Offline phantom photon
Re: Fitting Grips
« Reply #9 on: March 27, 2008, 10:38 PM »
I just stuck a set of grips on a couple of hours ago using Sure deoderant - always works for me   :daumenhoch:
Clean
Re: Fitting Grips
« Reply #10 on: March 26, 2011, 10:57 AM »
Bump......
Just found this; Sure Anti Perspirant works a treat!  :2funny:
Offline 58 delray
Re: Fitting Grips
« Reply #11 on: March 26, 2011, 11:39 AM »
i've always used the hairspray method, ellnett seen to work best  :daumenhoch:
