976298
lemus
June 22, 2026, 04:33 PM
giro query
Topic: giro query (Read 2265 times)
jedi
giro query
April 30, 2008, 07:01 PM »
watching the dew tour i notice that the 2 cables from the giro look like they go straight into the lever.anyone know what giro this is???
BrianP
Cherry Picker
Re: giro query
April 30, 2008, 07:18 PM »
it's just a regular gyro matey, but with either a dragonfly gemini or a snafu cable
they work a charm
Brian.
jedi
Re: giro query
April 30, 2008, 07:48 PM »
eh???
macky
Re: giro query
April 30, 2008, 07:53 PM »
Yeahh... i got the Fly cable... well better than the regular upper gyro cables!!
it's just two seperate upper gyro cable's connected to a wider nipple!! they work nice!!
http://www.alansbmx.com/product_info.php?cPath=32_55&products_id=888
jedi
Re: giro query
April 30, 2008, 07:55 PM »
do they go into the lever or do you need a joinyupythiny
macky
Re: giro query
April 30, 2008, 07:59 PM »
They go straight to the lever... i think for some of them , you need certain lever's to use em... but i've got
a Fly dragon fly cable to a Odyssey lever, mine works fine!!
jedi
Re: giro query
April 30, 2008, 08:02 PM »
mmmmmmmmmmmmmmm i feel like going back to giro
macky
Re: giro query
April 30, 2008, 08:07 PM »
I used to run em with tech 77 lever's too!! the difference in the brake was unbelievable!!
Well worth try'n em out!!
BrianP
Cherry Picker
Re: giro query
April 30, 2008, 08:22 PM »
i think that cable in the first pic is specifically for an odyssey modulever, but the theory is fairly similar, and like davemc says, one like his red cable will fit pretty much any new school lever.
i've got a gemini cable on an odyssey monolever in this pic, with dual lower cables too:
Brian
jedi
Re: giro query
April 30, 2008, 08:30 PM »
is it more or less powerfull than a single linear rear brake?
macky
Re: giro query
April 30, 2008, 08:48 PM »
I think if you wanna use a gyro, then these cables make your brake smoother and sharper i think!!
mine were spongy on regular gyro cables... a lot better now... and im only using the upper dual cables!!
subversion
Re: giro query
Reply #11 on:
May 01, 2008, 03:10 PM »
Odyssey M2 would be the best way to go, formerly 'modulevers'. The lever has a wider housing to accept the dual cable which is reduced to a single short wire to the cable nipple all inside the lever as opposed to the older style splitter half way down the cable
http://www.albes.com/browseproducts/ODYSSEY-M2-LEVER-(small--med-or-trigger).html
jedi
Re: giro query
Reply #12 on:
May 01, 2008, 03:33 PM »
TwoBobRob
Site Supporter
900 Air
Re: giro query
Reply #13 on:
May 01, 2008, 04:26 PM »
I have a Modulever here you could buy from me if the mood takes you
Hardly used. I'm taking the gyro off my cruiser.
jedi
Re: giro query
Reply #14 on:
May 01, 2008, 04:33 PM »
will let ya know.still looking into it.may require a new frame since i ahem.........drilled the tabs off
TwoBobRob
Site Supporter
900 Air
Re: giro query
Reply #15 on:
May 01, 2008, 04:36 PM »
Hehehe..... that'll learn ya
I bet someone on here has a pair of the removable ones lying around they're not using..... A little bit of cheeky drilling and tapping should see you right?
jedi
Re: giro query
Reply #16 on:
May 01, 2008, 04:38 PM »
mine were supposed to be removable but i may have rounded them off........................................alledgedly
TwoBobRob
Site Supporter
900 Air
Re: giro query
Reply #17 on:
May 01, 2008, 04:46 PM »
If I knew you better I'd call you a meat head......
But I don't, so I won't
jedi
Re: giro query
Reply #18 on:
May 01, 2008, 04:47 PM »
do it up til it strips,then back off a quarter
subversion
Re: giro query
Reply #19 on:
May 01, 2008, 07:50 PM »
Still using the Modulevers here, great levers
they're the OE versions with the smaller barrel adjusters than the originals
Here's the original version (running a single cable, you just swap out the cable adapter in the lever) The barrel adjusters on these are BEEFY!
giro query
