giro query
<< < (4/4)
TwoBobRob:
Hehehe.....  that'll learn ya   ;D
I bet someone on here has a pair of the removable ones lying around they're not using..... A little bit of cheeky drilling and tapping should see you right?
jedi:
mine were supposed to be removable but i may have rounded them off........................................alledgedly
TwoBobRob:
If I knew you better I'd call you a meat head......
But I don't, so I won't   :LolLolLolLol:
jedi:
do it up til it strips,then back off a quarter    :LolLolLolLol: :LolLolLolLol:
subversion:
Still using the Modulevers here, great levers :daumenhoch: they're the OE versions with the smaller barrel adjusters than the originals
Here's the original version (running a single cable, you just swap out the cable adapter in the lever) The barrel adjusters on these are BEEFY!
Navigation
[0] Message Index
[*] Previous page
Go to full version
