976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 23, 2026, 08:11 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  z rim clean up
Author Topic: z rim clean up  (Read 2218 times)
mattnice
z rim clean up
« on: May 08, 2008, 11:33 AM »
just bought a white pair of z rims,whats the best way to get them sparkling again and remove brake block rub?
cheers
Matt
Offline JAY
Re: z rim clean up
« Reply #1 on: May 08, 2008, 11:47 AM »
If someone has the link to bleeching white tuffs,same thing.
Basically scrubb with scourer using jif or whatever its called now until clean.
Soak in bleech (not diluted)for week in large container. Just buy cheap bleech form Tesco 27p stuff as you will need a fair bit.
It take alot of patience,but it'll be worth it .
Sure someone does Z rim decals for rims.
Hope this helps
mattnice
Re: z rim clean up
« Reply #2 on: May 08, 2008, 12:26 PM »
cheers
do i need to strip them down?or can i do with them still with hubs and spokes?
motomagII
Re: z rim clean up
« Reply #3 on: May 08, 2008, 02:20 PM »
the ones you just got need bit work they need stripping down firstly.then wet dry or scalpel off the brake rub .clean with jif or similar until as clean as you can get em then into bleach for couple weeks or so .they are cream not white anyways i believe
mattnice
Re: z rim clean up
« Reply #4 on: May 08, 2008, 02:31 PM »
cheers
Offline jT Racing
  • i like bikes. :/
Re: z rim clean up
« Reply #5 on: May 08, 2008, 10:22 PM »
you worry me greg. scalpel :(
ding dong
motomagII
Re: z rim clean up
« Reply #6 on: May 09, 2008, 09:39 AM »
it works though  :LolLolLolLol:
dct
Re: z rim clean up
« Reply #7 on: May 09, 2008, 09:42 AM »
harris for the decals  :daumenhoch:
Re: z rim clean up
« Reply #8 on: May 09, 2008, 03:10 PM »
If your removing the hubs, remember to get the freewheel off first :daumenhoch:
sonic-1
Re: z rim clean up
« Reply #9 on: May 09, 2008, 03:35 PM »
or yer could go buy some jif sink cleaner with bleach n give em a good scrub with that after usein some wet n dry sand paper p600 to get the break marks off first
once yer done rinse well n rub spokes with wd40 or like to stop em coroding
mattnice
Re: z rim clean up
« Reply #10 on: May 09, 2008, 09:26 PM »
cheers ill crack on with these when i get them
