976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 23, 2026, 10:55 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Painting over Chrome
Author Topic: Painting over Chrome  (Read 1863 times)
Offline Gary72
« on: May 14, 2008, 07:53 PM »
What is the best way to prepare chrome for painting, any special primer, or just rough them up with sandpaper. Going on a racer so not a show bike otherwise would ship off to SBD.
rakas17
Re: Painting over Chrome
« Reply #1 on: May 14, 2008, 08:19 PM »
you should realy get it stripped by a plating firm, they probably wouldnt charge much for this...  if its just for rasping out the gate then keying it up with about 180-240 should be fine...
Offline superbikedan
« Reply #2 on: May 14, 2008, 10:53 PM »
gal, i use 120 grit, it seems to work really well, keys in lovely and i feel safe to put a
coat of paint on the chrome, also 120 takes out surface rust and minor pitting easy :daumenhoch:
Offline Gary72
« Reply #3 on: May 14, 2008, 11:19 PM »
Cheers guys :daumenhoch:
Offline ORB
« Reply #4 on: May 14, 2008, 11:34 PM »
Acid Etch Primer is your friend
12
sonic-1
« Reply #5 on: May 15, 2008, 02:40 PM »
p120 will work great then a nice primer , or get it blasted
« Reply #6 on: May 15, 2008, 05:46 PM »
gary use 40 grit on it lol
that will give it the nice thrown down the rd look
  on a serious note i use scotch brite red pads to
key stuff works a treat
Offline Gary72
« Reply #7 on: May 15, 2008, 07:34 PM »
Done one today at work using a die-grinder with attachment for round discs of paper or scoring pad material, only 2 inch discs, does about 15000 rpm, done a good job with scouring pad disc. :)
