976289 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 12, 2026, 10:01 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Removing Anodising
Author Topic: Removing Anodising  (Read 9201 times)
Mr Rusty
Removing Anodising
« on: July 31, 2005, 09:09 AM »
I've got a pair or Red Shimano DX pedals where most of the red has come off the platforms and I'd rather strip it all back to silver.  Paint stripper and a wire brush has got me some of the way there but it's very slow going and I can't get thos hard to reach places.
Have tried to remove the spindle and bearings so I could soak them but stuck fast.
Any ideas  ???
Rusty by name Rusty by nature  :D
Offline Mattskybeat
Re: Removing Anodising
« Reply #1 on: July 31, 2005, 09:38 AM »
b & q costic soda, mix with water and drop em in for about 30 to 45 seconds, do it outside though, when it is done rinse under cold tap, do not touch with hands until you have rinsed off, it burns like hell
scary_leary
« Reply #2 on: July 31, 2005, 10:40 AM »
works better in an ikea bin ;)
Offline Mattskybeat
« Reply #3 on: July 31, 2005, 10:43 AM »
ah yes but some silly people dont wear gloves !!!!! no idea about health and safty   ;D
Offline Waxintaxin
« Reply #4 on: July 31, 2005, 01:02 PM »
DXs are not anno so do not use caustic soda as it will make your pins fall out, if some of the red came of with paint stripper then carry on with that, nitromors will eat it off easy,
caustic soda does remove anno , but as DXs are plastic coat then watch out, as the plastic coat does not come off with caustic soda , I know i have tried it, what will happen is the soda eats the alloy and loosens the pins as they are steel and they then fall out , leaving the coat on but no pins!
Rich
Mr Rusty
« Reply #5 on: July 31, 2005, 05:08 PM »
aahh I see I have a lot to learn.  Where can i get Nitromors Rich ?
Offline Waxintaxin
« Reply #6 on: July 31, 2005, 05:29 PM »
bnq , its in a green tin , with the paint strippers
scary_leary
« Reply #7 on: July 31, 2005, 07:36 PM »
if you've got any Nitromors left over sick ya dick in it!.....im telling ya,  its a mind scrambler :D
Mr Rusty
« Reply #8 on: July 31, 2005, 08:19 PM »
 ;D ;D ;D  Think I'll stick to the pedals for now - but you never know  ;)
Offline Nosnod
« Reply #9 on: July 31, 2005, 09:02 PM »
Will the caustic soda method work on Suntour XC-II cages??
Also with the anodising removed, if you do not re-anodise will they eventually start to rust??
scary_leary
« Reply #10 on: July 31, 2005, 09:26 PM »
no..u can only anodise alloy..alloy don't rust
Offline ORB
« Reply #11 on: July 31, 2005, 11:36 PM »
alloy oxidises (sp) (pissed)
Just cluean em up, polish, and if required, paint
12
Mr Rusty
« Reply #12 on: August 03, 2005, 10:45 PM »
Got the Nitromors and removed the colouring tonight - well easy.  Cleaned them up in about 20 minutes and back on the bike (compared to about an hour spent scrubbing with paint stripper previously to limited effect)
Cheers Rich
