976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 24, 2026, 07:49 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  REDLINE PRO-LINE CRANK - WHAT AM I MISSING???
Author Topic: REDLINE PRO-LINE CRANK - WHAT AM I MISSING???  (Read 1820 times)
« on: May 31, 2008, 11:11 AM »
These are the new ones, the single pinch jobbers. Ratty's installing instructions doesn't cover these new ones so can anyone help me with these? Want to know:
1) What should be in the box - have you got a photo of all the parts? Was bought off here a little while ago but they were used ones but in good nick and i'm not sure I have all the bits...
2) How do you fit them? Box didn't come with any instructions :(
Any help would be appreciated.
Thanks,
Matt  :)
« Last Edit: May 31, 2008, 01:59 PM by Swivel »
FuNMoNsTeR
Re: REDLINE PRO-LINE CRANK FITTING
« Reply #1 on: May 31, 2008, 11:33 AM »
The Prolines were wider arms with single pinch fitment. They come with exactly the same hardware as the twin pinch flites. They should fit exactly the same too, just one pinch bolt less to tighten on each side  :)
Re: REDLINE PRO-LINE CRANK - WHAT AM I MISSING???
« Reply #2 on: May 31, 2008, 01:57 PM »
Guys,
Ok here are the photos of the Redline Proline crank what I bought a while back. Just had the spindle sent to me... but from looking at the box, it looks as if I have some bits missing. What do you reckon? Looks like that black part that goes around the nut is missing and inside that part of the arm (not where the pedal goes) looks as if something screws into that also?
Have I got everything here to fit it together or from what you can see, am I missing stuff?
Also what are the stages of fitting this crank to my gt?
Thanks,
Matt  :daumenhoch:
« Last Edit: May 31, 2008, 02:03 PM by Swivel »
« Reply #3 on: May 31, 2008, 02:13 PM »
they only dust covers matt and ure missing all the washers and top hat aswell
unless you didnt take a pict of em
« Reply #4 on: May 31, 2008, 02:23 PM »
Nope that's all I was sold  :( Will contact the guy now....
FuNMoNsTeR
« Reply #5 on: May 31, 2008, 03:04 PM »
and you are missing the little round top allen bolt that bolts into the drive arm to secure the chainring  :daumenhoch:
Offline Gary72
« Reply #6 on: May 31, 2008, 06:41 PM »
You can get the covers and spacers here, you will need MID for 19mm axle, not in stock.
http://www.customriders.com/prodshow.asp?prodid=10430&cat=10&parent=1001&sid=3
Or if you want spare bearings aswell
http://www.customriders.com/prodlist.asp?a=cat&cat=8&parent=1001&sid=3&sort=3
You want US or MID 19mm, all a MID bottom bracket is, is a US without the cups.
Chainring bolt
http://www.customriders.com/prodshow.asp?prodid=2164&cat=10&parent=1001&sid=3
There are 2 types of bolt 1 with a coarser thread
http://www.customriders.com/prodshow.asp?prodid=4967&cat=10&parent=1001&sid=3
If you want any help. PM me and I will give you my phone no.
Gary
FuNMoNsTeR
« Reply #7 on: May 31, 2008, 08:30 PM »
I have a bolt set which might suit you, it was sold to me as being for flights but only came with 2 pinch bolts. Anyway it has all the bits, all bolts, spacer tube, top hat washer etc etc
I don't need it so you're welcome to it if you think it would be useful  :daumenhoch:
What a nice fella :)
and  :LolLolLolLol:  at the pig salt n pepper pots
Offline Gary72
« Reply #8 on: May 31, 2008, 09:19 PM »
Wondered what you was talking about at first, had to look twice :shocked:
Matt I think a pic of them would make a good avatar :LolLolLolLol:
« Reply #9 on: June 01, 2008, 09:45 AM »
Hahaha they are making bacon lads  :LolLolLolLol:  ;D
Thanks a lot Kang, definately take those off your hands.... send me a PM with what you want for them and your paypal addy and i'll send you the readies over.
Many thanks,
Matt  :daumenhoch:
