976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 24, 2026, 11:51 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Help IDing frame?
Author Topic: Help IDing frame?  (Read 3104 times)
firebird4130
Help IDing frame?
« on: June 02, 2008, 02:27 PM »
Can anyone please help me identify this frame, the forks are stamped Akisu on the dropout ,and on the bottom bracket it is stamped DSBM with a row of numbers underneath it.
Fraz
Re: Help IDing frame?
« Reply #1 on: June 02, 2008, 02:29 PM »
Im thinking CyclePro. A mate of mine got one out of a cataloge in about 81/82. Just like that with blue (non skyway) tuffs.
(I could be wrong about the name, but Im sure it was a cataloge bike.)
firebird4130
« Reply #2 on: June 02, 2008, 02:38 PM »
Ah so No kuwahara then,.......... nevermind it's still my first looptail BMX I think
JT71
« Reply #3 on: June 02, 2008, 03:03 PM »
what's a looptail?
« Reply #4 on: June 02, 2008, 03:27 PM »
Ammaco matey I believe, similar Ammaco style forks also  :daumenhoch:
firebird4130
« Reply #5 on: June 02, 2008, 05:00 PM »
~I've Looked up cyclepro and ammaco and this looks similar to both does anyone know about the serial numbers of either frame?
HEYWOOD BMX
« Reply #6 on: June 02, 2008, 05:25 PM »
 :) Looks very CyclePro to me,never seen an Ammaco with the same headtube gusset......
firebird4130
« Reply #7 on: June 02, 2008, 06:43 PM »
thanks a lot, so that's 2 for cycle pro, I'll go with the majority. So are they collectable, how much do you think it's worth?
firebird4130
« Reply #8 on: June 03, 2008, 06:52 PM »
Ah I see, silence speaks volumes  :LolLolLolLol:
HEYWOOD BMX
« Reply #9 on: June 03, 2008, 06:58 PM »
 :) Don`t be like that! I know no more,I may even be wrong! Don`t think it`ll be particularly valuable but if it was mine,I`d hold on to it as there can`t be too many around.
djgivvinup
« Reply #10 on: June 03, 2008, 07:05 PM »
Not sure what it is but i'll go Ammaco too, jus cos i've had two Ammaco frames both with serials starting DSBM followed by numbers..also both with Akisu forks....   :daumenhoch:
firebird4130
« Reply #11 on: June 03, 2008, 10:11 PM »
just when I thought it was solved, the plot thickens!
firebird4130
« Reply #12 on: June 03, 2008, 10:24 PM »
I've looked at some old posts and there's some other ammaco frames with dsbm and akisu forks, so it must be one right? does anyone know what stickers would it have had?
firebird4130
« Reply #13 on: June 03, 2008, 10:27 PM »
thanks for the info strikey  :daumenhoch:
firebird4130
« Reply #14 on: June 28, 2008, 09:57 PM »
I finally have an Id for this frame is a falcon pro alpha, thanks southern andy  :daumenhoch:
http://www.radbmx.co.uk/forum/index.php'topic=9965.0
Offline southern andy
« Reply #15 on: June 29, 2008, 07:49 AM »
You're welcome mate. I only sort of knew because it's very similar to a Falcon Pro cruiser i recently acquired, apart from the bit in the gusset and the extra bit by the bottom bracket it's the same.
djgivvinup
« Reply #16 on: June 29, 2008, 10:16 AM »
Glad you got this sorted, i suppose just because the seriel starts with DSBM doesn't automatically make it an Ammaco, must just be made in the same factory?   :-\
firebird4130
« Reply #17 on: June 29, 2008, 11:47 AM »
yeah probably or they could both have made an identical frame , thanks for the suggestions :daumenhoch:
