976289
Homebrewhero
June 12, 2026, 05:51 PM
Brake levers?
Topic: Brake levers? (Read 7087 times)
Moose
540 Air
Brake levers?
July 31, 2005, 05:16 PM »
Why are some not 'V' brake compatible?
Rombloke
Team Owner
My life is Radbmx
do one
Re: Brake levers?
July 31, 2005, 06:36 PM »
surely all levers are compatible with all brakes...doesnt it just depend on the cable ends at the lever....
Dave
haro, how do you do
Moose
540 Air
Re: Brake levers?
July 31, 2005, 06:55 PM »
My thoughts exactly, so why do some say 'V' brake compatible' or 'Not V-Brake compatible'?
Dingobmxer
Founding Fathers
900 Air
Re: Brake levers?
July 31, 2005, 07:32 PM »
Its the distance from the pivot point of the lever to where the cable is situated, (& how much cable is pulled) there are two different types, use the wrong one and the brakes are mushy and dont work
Hope this helps?
DINGO
Re: Brake levers?
August 01, 2005, 05:11 PM »
v brakes require a different pull length
if you use normal levers they just dont get the pull right
Rombloke
Team Owner
My life is Radbmx
do one
Re: Brake levers?
August 01, 2005, 05:37 PM »
ok...moose you stupid fool...i knew really....not
now we all know
Dave
haro, how do you do
Brake levers?
