976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 24, 2026, 03:09 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  mongoose pro class 24
Author Topic: mongoose pro class 24  (Read 1826 times)
Offline Bigfrawg
« on: June 11, 2008, 09:32 AM »
now here's the thing, i've bought myself a pro class 24 and was thinking of getting it powdered.as you know there is a mongoose badge on the head tube which is rivetted on, taking it off is not the problem but how can i re-attatch it without useing screws  so to keep a factory look. (i know they only came in chrome so powdering the frame will not be a factory finish, but you know what i am getting at...hopefully!)
any help from you mongoose gurus would be appreciated.
thanks in advance.
Re: mongoose pro class 24
« Reply #1 on: June 11, 2008, 09:57 AM »
Stick it back on & stick on the rivets ( heads only ) ? .
Know anyone with a spare 24" Pro Class rim ? .
Offline Bigfrawg
« Reply #2 on: June 11, 2008, 10:05 AM »
thats what i was thinking, as for the rims can't help there matey.
« Reply #3 on: June 11, 2008, 10:35 AM »
Ref the badge , I'm sure some goose guys will pipe up & enlighten us all  ;)
Offline Brandy Truffle
« Reply #4 on: June 13, 2008, 11:08 AM »
theres a guy on ebay that sells the headbadge rivets now and again for Old Geezers that restore their old Raleigh Team Frames from the 70's and 80's where the Raleigh badge was a brass embossed thing,obviously when they have a refinish they need to remove and reattach a super splendid badge. Read somewhere they glue them on and tap rivets into holes gently so as not to flatten the domes,then hey presto good as new..
do a search for raleigh head badge or headbadge rivet rivets etc and he lists them every now and then,or check out yer local hardware place and match the rivets yourself..  :daumenhoch:
Offline Bigfrawg
« Reply #5 on: June 13, 2008, 11:48 AM »
i thank you :4_17_5:
Offline Steve P
« Reply #6 on: June 13, 2008, 12:03 PM »
Here you go ... !!! CLICKETY CLICK !!!   :daumenhoch:
Steve
Offline Bigfrawg
« Reply #7 on: June 16, 2008, 07:50 AM »
well done boys !
thanks for the help. :daumenhoch:
