976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 24, 2026, 03:25 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Putting grips on bars...
Author Topic: Putting grips on bars...  (Read 1837 times)
funkwit
« on: June 17, 2008, 08:30 PM »
...does anyone have any good tricks to get A'ME grips on to bars (relatively) easily? It's always a major mission for me and I end up with blisters on my hands from the pushing and tugging!!
Re: Putting grips on bars...
« Reply #1 on: June 17, 2008, 08:35 PM »
WD40. slides on, and does something that corrodes the inside surface of the grip to make them stick.... within minutes.
Offline kuwahero
    • Western Titans
« Reply #2 on: June 17, 2008, 08:37 PM »
liberally spray the inside of the grip with hairspray and a touch on the bars and slide into place.
be sure to do it quickly before the hairspray dries. once there dry they wont move.
I have done this to my grips since I was twelve and never had a problem.
too get the back off slide a thin screwdriver down the inside and waggle around while spraying GT85 then just twist them off
marc :daumenhoch:
Offline brass monkey!
« Reply #3 on: June 17, 2008, 08:38 PM »
i always use WD40 - works a treat
Offline Jt
« Reply #4 on: June 17, 2008, 08:41 PM »
spit.
« Reply #5 on: June 17, 2008, 08:54 PM »
WD40.  Works a treat   :daumenhoch:
djgivvinup
« Reply #6 on: June 17, 2008, 09:06 PM »
tap water..plain & simple   :daumenhoch:
octane75
« Reply #7 on: June 17, 2008, 10:05 PM »
wd40 inside the grip to get them on,  and to get em off perfect, to re-sell maybe, fill up your sink with hot tap water leave em to heat up and soak for 5 mins and they should slide rite off.
Offline phantom photon
« Reply #8 on: June 17, 2008, 10:49 PM »
Sure for Men deodorant works for me and it makes it smell nice :daumenhoch:
funkwit
« Reply #9 on: June 18, 2008, 09:19 AM »
Nice one guys, I'll give the WD40 a go.
Cheers!!
zed4130
« Reply #10 on: June 18, 2008, 09:21 AM »
spit, its free, and dries fast,  :4_17_5:
« Reply #11 on: June 18, 2008, 09:31 AM »
i use spray on carpet adhesive. you have to cut the fookers of when you want to replace them, but they never ever budge, which is good if its a rider.....
