976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 24, 2026, 08:20 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Painting a stem...
Author Topic: Painting a stem...  (Read 1316 times)
GREMLIN
Painting a stem...
« on: June 28, 2008, 05:09 PM »
Hey lads.  :)   I had a Suntour stem through the post this morning from OrgasmDonor (thanx Daz m8).
I've picked it up to re-furb then put onto my Kuwi'.
Just after it arrived...
After a quick session with Nitromors...
Right, anyhow I'm going to be coating it in black.
So should i bother attacking it with Oven pride to strip the anno off or should i use the anno as a base to coat over?
Rattle can should cover the anno (after a keying in) shouldn't it?
Or would it still need some primer?
Or just strip totally then , primer, top coat?
Any thoughts?     Grem'.  :daumenhoch:
Offline PHIPPSIO
Re: Painting a stem...
« Reply #1 on: June 28, 2008, 05:36 PM »
Yeah you will need to remove the anno first. Last one i did i just dusted it with a light primer and then straight into paint. I tried painting a red anno shainring last year and it just doesnt take
GREMLIN
« Reply #2 on: June 28, 2008, 05:53 PM »
Oven pride it is then.  Thanx m8  :daumenhoch:  G.  :)
« Last Edit: June 28, 2008, 06:44 PM by Gremlin »
GREMLIN
« Reply #3 on: June 28, 2008, 06:45 PM »
After a couple of minutes in Oven pride and a quick scrub...  G.  :)
Offline sawzall
« Reply #4 on: June 28, 2008, 07:48 PM »
gav you will need to use an etch primer on it before you prime and paint ;)
GREMLIN
« Reply #5 on: June 28, 2008, 08:04 PM »
Hey Phil.  So use etch primer then primer before top coats ?  Cool.  :)
I hope the layers aren't going to build up and wipe out the Suntour text ?    G.  ???
Offline sawzall
« Reply #6 on: June 28, 2008, 08:07 PM »
gav you will only need to dust on a light coat of etch primer then a couple of light coats of primer then paint,so you shouldn't have any probs with logo ;)
GREMLIN
« Reply #7 on: June 28, 2008, 08:14 PM »
Thanx m8  :)  If i go too mad i can always strip and try again, and again  :D  G.  8)
