976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 25, 2026, 05:11 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Truing Wheels
Author Topic: Truing Wheels  (Read 1313 times)
Longun
Truing Wheels
« on: July 08, 2008, 11:33 PM »
Any recommendations for someone/a shop in the London area to true up some wheels I've just built. They're not far off, but I'm not best at getting the perfectly true, proper tension bit especially without a truing stand.
jedi
Re: Truing Wheels
« Reply #1 on: July 09, 2008, 12:01 AM »
my lbs does them good.
marshalls cycles,wgc.
01707-393322 :daumenhoch:
Re: Truing Wheels
« Reply #2 on: July 09, 2008, 08:41 AM »
if you want to do them yourself Steve just use your bike upsidedown, bang the wheel in the forks and use the fork to true them off??
Re: Truing Wheels
« Reply #3 on: July 09, 2008, 05:30 PM »
Grips in Rayleigh.  Tell Ian that Rob Steele says hello  :)
or
I can do them for you, although if you want a perfect, perfect job then I'm not your man I'm afraid. you're welcome to borrow my trueing stand if you like?
Re: Truing Wheels
« Reply #4 on: July 10, 2008, 12:29 PM »
I'd do them for you Steve but it's a bit far to travel now  :LolLolLolLol:
Longun
Re: Truing Wheels
« Reply #5 on: July 10, 2008, 01:09 PM »
Well I ended up having a go last night and I'm pretty happy with the results, no more that 1mm movement in any direction. Reckon they'll do now.
Re: Truing Wheels
« Reply #6 on: July 10, 2008, 01:33 PM »
Kewl  :daumenhoch:
Re: Truing Wheels
« Reply #7 on: July 11, 2008, 10:02 PM »
Good enough for me, mine are never better than that....
