976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 25, 2026, 05:12 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Front wheel spindle problems.
Author Topic: Front wheel spindle problems.  (Read 2091 times)
Offline southern andy
« on: July 10, 2008, 08:57 PM »
I've just gone to put a front wheel in to a set of LG's and they wont go in. The spindle is 10mm as is the gap in the drop outs.
I've been advised that the spindle needs some flat bits filed in to them. I know for fact that on my spare Arayas the spindles have flat bits in them but on these Sumos the spindle is fully round.
What is the best way to do this, is it just a case of putting the wheel in a vice and slowly filing away or can new 10mm spindles be bought as the hubs need stripping anyway for a re-grease.
Re: Front wheel spindle problems.
« Reply #1 on: July 11, 2008, 02:16 PM »
Can no-one help me then. ???????????????
Panic stations :LolLolLolLol:
« Reply #2 on: July 11, 2008, 02:33 PM »
sorry mate i thought someone would've by now!
what i did mith mine was to take the old axle out and change the barings and re-grease.....then put it all back together and then filed down two small flat spots on each side so they slipped into the forks......making sure not to go too deep on the axles though  :daumenhoch:
i'm not sure the flattened axles are easy to get hold of new??
Offline se-bmxer
« Reply #3 on: July 11, 2008, 02:35 PM »
i might have an old axle with the flats bits you require but only for open bearing hubs
LYK, soon
« Reply #4 on: July 11, 2008, 02:43 PM »
Cheers Pickle,
What about the thread though, did it still work after you filed them.
LYK, soon
Cheers Jai, that would be great. Also i received the brake cable today mate, many thanks.
Andy
subversion
« Reply #5 on: July 11, 2008, 02:48 PM »
Have you tried a 3/8" axle?
Offline se-bmxer
« Reply #6 on: July 11, 2008, 02:50 PM »
Hi m8
i have one out of an old SR hub 10mm axle so will fit all open bearing hubs, i'll get it in
the post asap, free  :daumenhoch:
Jai
« Reply #7 on: July 11, 2008, 03:06 PM »
cool there you go mate.........as for my filing effecting the thread?  well i only filed where the forks would fit over the axle, so the axle nut didn't go over that section  :daumenhoch:
« Reply #8 on: July 11, 2008, 05:27 PM »
Hi m8
Jai
Cheers jai, you're a star mate.  :4_17_5:
Andy
Didn't even think about doing it that way pickle, i was gonna file the whole lot off.  :-[ :-[ :-[ :-[  Many thanks for your help mate.
Andy
« Reply #9 on: July 12, 2008, 10:07 AM »
just prise the fork openings wider then hammer them back in again ;D
