mongoose 1 piece crank
MartyC:
Might sound a silly question but are the bearing cups pressed all the way in?
Would be useful to see pics of it to see what's going wrong :daumenhoch:.
meticulous:
ok here we are , bearing cups are pressed in all the way and i have done everthing correct, i have noticed that there is a largeish gap between the spider and frame, thats why i originaly tried removing the spider washer, hard to tell on photos but the last lock nut is just on the thread.....
GREMLIN:
I've not come across a drive-side nut that hasn't tightened up to the spider before. Even without a spacer washer.
Howz about trying a powerplate where it's a Goose crank? It's a bit thicker than a spider, which means you prob would be able to lose the spacer then.
Bringing the thread through for the lock nut on the non drive side...?
Do you have a close up pic of the crank and parts whilst off the bike ? G. :)
meticulous:
ive never come across this too. dont realy want to drop the spider as its a mongoose stamped one, i'm going to try another bearing nut on the drive side to see if its just an alien bearing nut or sumat
meticulous:
tried another bearing nut but the thread is differant and anyway it still seat the bearings in place just the same. the trouble is that the drive side bearings does not fit in the cups as square as it does on the other side
it remains wobbley when pushed in place, its the same when tried on the other side so its not the cups, the non drive side fits flush up to the cups and is not wobbley
this is the kit
i am sure i am not doing anything wrong, it would improve if i could get rid of the spider washer but it defo needs one as the bearing nut cannot go over a flat piece that protrudes from where the spider sits, it would have to be at least 1mm, and possibly 2mm, as the original is the standard 3mm maybe... pheeew.
have i confused everone? :-\
Navigation
[0] Message Index
[*] Previous page
Go to full version
