976300 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 26, 2026, 01:15 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  shims
Author Topic: shims  (Read 1769 times)
tobybrown35
shims
« on: July 21, 2008, 08:59 PM »
   got a inch chris king road bike headset instead of inch bmx one cups wobble in frame so need a shim 2 fit bout 2.6mm in difference any help appreciated cheers  :daumenhoch:
Re: shims
« Reply #1 on: July 21, 2008, 09:00 PM »
coke can?
tobybrown35
Re: shims
« Reply #2 on: July 21, 2008, 09:03 PM »
  does it work
Re: shims
« Reply #3 on: July 21, 2008, 09:20 PM »
i've used em to shim out seat posts and also used it to shim out some old bearings on an old full suss frame, they lasted longer than the original shims!
thecrooch
Re: shims
« Reply #4 on: July 21, 2008, 09:21 PM »
if you look on the chris king website or www.aspirevelotech.com you will find the exact difference.  it has something to do at the stack height.
Personally i dont think it would work and if you could get it snug im not sure i would want to ride it as is.
Re: shims
« Reply #5 on: July 21, 2008, 09:28 PM »
yeah i'd have to agree.....not good for a rider
tobybrown35
Re: shims
« Reply #6 on: July 21, 2008, 10:02 PM »
  found a shim on chainreaction with about a .2 difference allowing 4 paint it should fit snug would the stack height affect it
thecrooch
Re: shims
« Reply #7 on: July 21, 2008, 10:57 PM »
the thing with CK stuff is its engineered to an inch of its life and its only meant to do one thing.... i just wouldnt do it man..... itll only end in tears.. i just dont muck about with the front end... its all too near the face and dirt...
im done... nuff said...
fouronethreeoh!
Re: shims
« Reply #8 on: July 22, 2008, 07:43 PM »
I cant remember the exact dimensional difference between 1" road threaded headset, and 1" bmx headset.
But i cant see a problem with having a couple of rings (shims) made, to make the cups fit the frame properly.
This type of thing was available to make 1 1/8" headsets fit 1 1/4" cannondale/klein mtb frames.
I have had to shim the lower race on to the fork leg with shim steel (essentially sheets of coke can material), with no probs.
A well fitting ring would not affect the structural integrity of the headset.
