976300 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 27, 2026, 07:18 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  tip find ta
Author Topic: tip find ta  (Read 1567 times)
skaterpostie
tip find ta
« on: August 23, 2008, 06:57 PM »
ok crank arms need rechroming and will do when i can afford it,took cheap option and repainted for now,also been told ive applied wrong decals
Bettyswallocks
Re: tip find ta
« Reply #1 on: August 23, 2008, 07:02 PM »
Cool....  8)
Any before photos?
Bettyswallocks
Re: tip find ta
« Reply #2 on: August 23, 2008, 07:05 PM »
Oops... Just found the other thread further down the page... no pic though...  :-\
Re: tip find ta
« Reply #3 on: August 24, 2008, 09:48 AM »
Quality tip find; frame needs some work on the seat tube though but man what a find if only for the cranks and spider  :daumenhoch:.
johnty22
Re: tip find ta
« Reply #4 on: August 24, 2008, 09:58 AM »
should the chain ring not sit on the outside of the spider ??? someone correct me if im wrong .
Re: tip find ta
« Reply #5 on: August 24, 2008, 10:18 AM »
Nope, not always but it can depending on the alignment with the rear sprocket/freewheel.  Putting it on the outside may pull the chain too far over and cause it to jump off under pressure (such as gates)  :daumenhoch:.
johnty22
Re: tip find ta
« Reply #6 on: August 24, 2008, 11:53 AM »
ahhhh u learn something every day mate i just saw the step in the spider and , thought it was for the ring to sit flush ,  :daumenhoch:
