976301 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 29, 2026, 11:14 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Black Metal
Author Topic: Black Metal  (Read 1532 times)
Offline R Al
Black Metal
« on: October 04, 2008, 08:59 AM »
Does anyone know how to get non painted parts back to that black metal look (Im sure theres a technical term  :LolLolLolLol:)
I've cleaned and polished some bits up , axles, bolts etc. but want them back to looking like original
Re: Black Metal
« Reply #1 on: October 04, 2008, 09:12 AM »
ive done this with a couple of bolts before, coated them in used old engine oil n hoyed them in a coal fire for a bit, it worked but i cant remember how good they looked. so that was alot of help wasnt it :LolLolLolLol:
Offline SteveG
Re: Black Metal
« Reply #2 on: October 04, 2008, 09:44 AM »
Used to do stuff like this as an apprentice. You have to heat whatever it is up until it's bright red (damm hot) then put it in a large container of oil.  You really need a large one as a small amount of oil will get very hot and possibly catch fire !
You can get chemical blacking which is used on gun barrels. I haven't used this myself but would save you having to heat stuff up a lot. There is always a risk that heating could cause things like axles etc to bend or crack.
I expect someone on here has found a good way to do it.
Offline Steve P
Re: Black Metal
« Reply #3 on: October 04, 2008, 10:03 AM »
This stuff works very well  :daumenhoch:
Re: Black Metal
« Reply #4 on: October 04, 2008, 10:43 AM »
thats what i did, all coming back to me now (was stoned when i did it, ya see n forgot how i did it and why in fact and what to, but i did it :LolLolLolLol:)
S1
Re: Black Metal
« Reply #5 on: October 04, 2008, 05:22 PM »
The trouble with heating stuff like that is you'll lose any previous heat treatments it may have had. try the kit from Frost.
http://www.frost.co.uk/item_Detail.asp?productID=8253&frostProductName=Metal+Blacking+Kit&catID=22&subCatID=21&FrostCat=Miscellaneous&FrostSubcat=Miscellaneous
