976301 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 29, 2026, 11:14 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  skyway coaster hub
Author Topic: skyway coaster hub  (Read 1681 times)
skyway
skyway coaster hub
« on: October 04, 2008, 05:51 PM »
anyone help?
i have a skyway with metal flange hub with freewheel kit on a coaster hub - anyone know how i can convert back to coaster hub?
thanks
Offline SteveG
Re: skyway coaster hub
« Reply #1 on: October 04, 2008, 07:25 PM »
You will need to replace the bit the freewheel screws onto with an original Suntour bit.  If you weren't too bothered you could get someone to weld the freewheel up and put a couple of spots on the bit it screws onto to stop it unscrewing. Bit of a bodge but it would save a few quid.
skyway
« Reply #2 on: October 04, 2008, 07:27 PM »
thanks for the reply - not too sure about welding it but will try to find suntour bits
anyone want to swap coaster brake hub guts for freewheel?
« Reply #3 on: October 04, 2008, 07:30 PM »
Post a photo if you can, but the freewheel should just undo & then you can attach a fixed cog  :daumenhoch:
skyway
« Reply #4 on: October 04, 2008, 07:38 PM »
will try and post a photo
sounds promising  - so all i need to try and find is the cog and the brake arm
Offline SteveG
« Reply #5 on: October 04, 2008, 07:44 PM »
No probably not a very good idea. You might need to get the brake "shoes" as well. Not sure if you have to remove them when fitting the freewheel bits.
steve Beech TA
« Reply #6 on: October 04, 2008, 09:03 PM »
I think i might have the answer to your problem mate, i have a nice NOS suntour coaster going spare. you can take the bits out of it and put them into yours. :daumenhoch: sorted
only prob is i have not got it at the mo i sent it to some one to see if they could convert an old type coaster which was not a suntour hub. but he will send it back if need be  :)
give me a pm  :daumenhoch:
moley
« Reply #7 on: October 04, 2008, 09:18 PM »
I have Steve Beech TA's Coaster and I'm holding it to ransom!!  :LolLolLolLol:
Steve, I could post it straight to him if ya want!!  :daumenhoch:
skyway
« Reply #8 on: October 04, 2008, 09:44 PM »
that would be great
how much?
steve Beech TA
« Reply #9 on: October 04, 2008, 10:54 PM »
I dont mind, i suppose it would be best to send it to me and i will send it on. or if you dont mind , can you describe it to him as in condition and all that and if he wants it then you can send you can send on to him, i was going to take a pic.
cheers steve :daumenhoch:
