976301 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 29, 2026, 11:15 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  BB BEARING REMOVAL ?
Author Topic: BB BEARING REMOVAL ?  (Read 1447 times)
Offline HARODAVE
« on: October 06, 2008, 04:56 PM »
 hiya all , i`m swapping the 3 peice cranks off my 06 sport over onto my zippo frame , i`ve got both the crank arms off and tapped the spndle out ,but how do i get the bearings out of the cups ? do the cups have to come out ( hope not  :-[) or can i jiggle the spacer out of the way and tap them out from the inside? ..and what is the best thing to put through so i don`t knacker them? don`t want to start twatting things with hammer and screwdriver before getting some advice ...cheers ...Dave
beaglepopper
Re: BB BEARING REMOVAL ?
« Reply #1 on: October 06, 2008, 07:19 PM »
Are they sealed bearing's? If so then yes you need to knock the cups out.  :daumenhoch:
fouronethreeoh!
« Reply #2 on: October 06, 2008, 07:23 PM »
If its an american bottom bracket,unfortunately you are correct that you have to persuade them out with a hammer.
There is no best thing really, something solid like a bar of sorts(socket extension bar).
I wrap the end of the bar with masking tape so it marks less, doesnt matter how hard you try you get a few dinks on the cups.
Use a good firm hit, then move the bar round a bit and do it again.
Once they start moving it gets easier.
p.s. mind your fingers  ;)
« Reply #3 on: October 06, 2008, 07:25 PM »
use a socket extension bar to tap them out.
you cant really control whether the cups come out of the bearings, or if the cups leave the frame.
luck of the draw.
pop it through the spacer tube, lever it up as far as it goes then tap. circulate the movement, and itll pop out.
Offline HARODAVE
« Reply #4 on: October 06, 2008, 07:27 PM »
thanks for the tips fellas ...had a look at various related subjects on here , with it being a newish frame i`m beginning to think that they`re the cartridge bearings that press straight in , no cups ....so i`ll have to take a deep breath and tw@ them out as carefully as poss then?
« Reply #5 on: October 06, 2008, 07:29 PM »
go fer it.
Offline HARODAVE
« Reply #6 on: October 06, 2008, 08:06 PM »
 :daumenhoch: PHEW  ..JOBS A GOOD UN!!  thanks for the help fellas ...used a socket extension wrapped in an old dishcloth ...bearings came out first ..then the cups ...after a lot of persuation ...now to get the old cups out of the zippo frame and the sport ones in without fooking my lovely new spray job , GENTLY DOES IT ....... CHEERS AGAIN LADS ..YOU ROCK !!!   :4_17_5:
« Reply #7 on: October 06, 2008, 08:07 PM »
good lad.
