976301 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 29, 2026, 02:42 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Profile crank removal
Author Topic: Profile crank removal  (Read 1308 times)
kevin rettie
« on: October 13, 2008, 01:20 PM »
Can anyone give me some advice on removing some Gen 2 cranks?
I bought and crank tool at the weekend but the threads don't fit the profiles.
Is there any other way of removing the arms without twatting it with a big hammer!
dan-dare
Re: Profile crank removal
« Reply #1 on: October 13, 2008, 01:24 PM »
Easy bud. Just remove a spindle bolt and knock the spindle through. Use a hammer and a piece of rod/drift. :daumenhoch:
moley
« Reply #2 on: October 13, 2008, 01:31 PM »
No!!  :(
The proper Profile tool is used for installing!!
For removing, the Profile tool is from the stone age.
Screw it in and use all that pent up anger and unleash the fury within!!
So whether you have the correct tool or not, its still hammer time!!  :(
I had a pair from the US (unmounted but screwed up) that no amount of hammer action would loosen.
I ended up using a vice at work to squeeze the profile tool and using the bb cup (which was installed) to brace it (with some aluminium sheet to protect the cup)!!
It worked but the handle on the vice is bent to fook!!
And there was no damage to crank set!!
Get the biggest heaviest hammer you can find!!!
Good luck!!  :daumenhoch:
HEYWOOD BMX
« Reply #3 on: October 13, 2008, 01:33 PM »
 :) About time Profile used metric threads and also put a thread around the inside of the spindle boss on the crank arm.At least then you could use a Park crank tool...
kevin rettie
« Reply #4 on: October 13, 2008, 03:00 PM »
Wish me luck then lads, american screwdriver it is then....
... just hope I dont snap my Harry Leary frame in the process!!!!
moley
« Reply #5 on: October 13, 2008, 03:53 PM »
Dont use anything sharp!!
Use an extension off a socket set or something similar!!
Then give it some grief!!  :knuppel2:
