976301
crissy_criss
June 29, 2026, 10:03 PM
Quick question guys
Topic: Quick question guys (Read 1348 times)
Torker pro-x
Quick question guys
October 26, 2008, 08:15 PM »
Just got hold of some forks for my Torker, not sure of the make but they are defo 1" thread. When the headset Is on should there be any thread showing at the top of the forks above the locking nut ie 5 mm? Or Is the tube too long? Thanks In advance
DIRTBIKER250F
Site Supporter
540 Air
Home sweet home
Re: Quick question guys
October 26, 2008, 08:26 PM »
You need a little spacer mate, or you could use a 1.2" washer
snav69
October 26, 2008, 08:45 PM »
are the forks 4" or 5"
i believe that torker did both and maybe you have some 5" ones and you are fitting them to a 4" headtube
I'm usually wrong on most BMX related topics
Torker pro-x
October 26, 2008, 08:54 PM »
They measure just under 6" from the base were the bearing sits to the top of the thread, or just under 4" to were the thread starts, hope this makes sense!!
snav69
October 26, 2008, 08:58 PM »
I would say that they are for a 5" headtube , Measure your headtube and if its 4" i reckon you have the wrong size forks
Torker pro-x
October 26, 2008, 09:28 PM »
Its a Pro -x with 4" top tube. Will they be ok to use with an extra locknut on?
Quick question guys
