976301 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 30, 2026, 04:06 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Bit of a tight spot (in chain)
Author Topic: Bit of a tight spot (in chain)  (Read 4784 times)
sweetbeats
Re: Bit of a tight spot (in chain)
« Reply #25 on: October 30, 2008, 06:07 PM »
Going to have a blast out to the offy later see how she goes...haro bitch :tickedoff:
mr.magoo
« Reply #26 on: October 30, 2008, 06:56 PM »
Same as Bill, all i've ever done, is position it so chain is correct tension at tightest point, but make sure that it is not too slack at slackest point :LolLolLolLol:
sweetbeats
« Reply #27 on: October 30, 2008, 06:59 PM »
Going to give her a pounding now :daumenhoch:
motomagII
« Reply #28 on: October 30, 2008, 08:24 PM »
pretty mudh as moley says unless the power disc is not holed central .listen to him ive had this problem so many times and hes spot on to clear it up
subversion
« Reply #29 on: October 30, 2008, 09:47 PM »
In my experience the top hat washer should be inserted into the spider from the inside (BB side) not the outside (crank arm side)?
Not if your top hat is deeper than the spider/chainwheel.   Then you have to put a Bowler hat (thingymajig) washer on the inside so it can tighten up!!
Thats how I noticed it getting pulled out of alignment!!  :shocked:
Break out the files & make it fit :daumenhoch:
moley
« Reply #30 on: October 30, 2008, 09:53 PM »
It was made out of some hardened metallic kryptonite or summat!!
Fook that, it could take me ages to file it and I'm far too lazy!!   :(
Luckily Bof had a bowler hat jobby to fit it!!  :daumenhoch:
rotorist
« Reply #31 on: November 02, 2008, 08:48 AM »
I've had this problem on both BMX and MTB singlespeeds, it has driven me nuts too as I like to run quite a tight chain.
I couldn't put it better than Gremlin, if your still not sorted check his post again.
Good luck.
« Reply #32 on: November 02, 2008, 11:24 AM »
Jay
What you need is a mallet, not one like this ...
but one like this...
Tap the spider into alignment and problem solved  :daumenhoch:
Marty  ;)
sweetbeats
« Reply #33 on: November 02, 2008, 08:35 PM »
Thanks for all your help fellas,
been out over the weekend and gave the pedals a pounding and the tight spots have slightly eased,think I will ditch the mirage power disc and get a trusty spider or redline bubble ;)
