976295 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 20, 2026, 04:04 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Straightening mags in the freezer - urban myth??
Author Topic: Straightening mags in the freezer - urban myth??  (Read 4666 times)
Preston Pirate
« on: January 25, 2006, 05:00 PM »
Does sticking slightly buckled mags in the freezer to straighten them really work, or is it an urban myth told to you by your mate's older brothers as a kid?
Sanmarcopizza
Re: Straightening mags in the freezer - urban myth??
« Reply #1 on: January 25, 2006, 05:06 PM »
it's Boll0ks
Offline Moose
« Reply #2 on: January 25, 2006, 05:16 PM »
It's an urban myth. If you buckle your mags, you should go to you local bike shop, they'll have a special spoke key for mags for 'trueing' them again  ;)
« Reply #3 on: January 25, 2006, 05:43 PM »
i thought it was true  ???.
Offline Nosnod
« Reply #4 on: January 25, 2006, 05:45 PM »
Well I thought you had to put them in a bath of boiling water, hand mould them back into shape then put them in the freezer!  :LolLolLolLol:
Donker
« Reply #5 on: January 25, 2006, 06:27 PM »
why dont you just try it, and let us all know
 :Great_Britain:
weston
« Reply #6 on: January 25, 2006, 07:37 PM »
it is true if you divvy's know anything about materials, depends which mag it is as they are made out of different plastics so it doesnt work for all of them :uglystupid2:
Donker
« Reply #7 on: January 25, 2006, 07:58 PM »
weston,
did you ever post pics of  your tuff wheel with a spoked wheel hub fitted?
Offline showtime
« Reply #8 on: January 26, 2006, 07:40 AM »
weston,
isn't that a Z rim  ::)
Preston Pirate
« Reply #9 on: January 26, 2006, 10:38 AM »
They're Aero Zytecs, in royal blue - not sure if the pigment makes a difference.
it's only a slight wobble, I might give it a try, don't suppose it's going to harm them..
Just wanted to check before I did it, coz the missis already thinks I'm a nutter buying 'little bikes' let alone sticking the wheels in the freezer!!
Offline ORB
« Reply #10 on: January 26, 2006, 11:32 AM »
Not true.
12
Preston Pirate
« Reply #11 on: January 26, 2006, 03:04 PM »
any top tips for straightening them then?
Or is it ze bin for the wheels and a re think?
For my own peace of mind, people have heard of this method/rumour before haven't they, just checking I didn't dream it!!
« Last Edit: January 26, 2006, 03:09 PM by Preston Pirate »
« Reply #12 on: January 26, 2006, 03:18 PM »
how do you know until you try.
« Reply #13 on: January 26, 2006, 05:48 PM »
i think if you have bent one, the plastic will be stretched
its the only way you can really bend one
Donker
« Reply #14 on: January 26, 2006, 05:55 PM »
if your going to try, heat them and over stretch in the opposite direction.
perhaps clamped to the dining table (to please her indoors) or a flat surface, with the wobbly bit overhanging and with a significant weight attached for a while.
« Reply #15 on: January 27, 2006, 12:11 AM »
get it in the freezer and see what happens.
« Reply #16 on: January 27, 2006, 12:20 AM »
OK,  I'll jump in.....  My opinion is this;
Freezer - bollocks. Urban myth. I think the wheels just contract a little with the temperature drop, i don't see how or why they would reshape....except;
I believe that all that can be done is to remove the tyre and tube and hang the wheel up somewhere by its axle.  If its going to do owt at all, it will now 'relax' and maybe, possibly relax back into shape....  So, it could be argued that the tyre and tube come off before it goes in the freezer, and then it relaxes and falls back into shape a little aided perhaps by a little contraction....
I have hung my tuffs up before and the following morning they have been true-er than the night before.   Or is that just my mind playing tricks on me...... :-\ :-\ :-\
madall
« Reply #17 on: January 27, 2006, 11:39 PM »
Your Du Pont Zytel rims will straighten if you freeze them as the temp drop below ambient for a sustained time will return them to the original shape they were when they left the mould, its like the same as a hair drier on your plastic moulded bumbers of your motor , what you have is one end of the scale for each material.
todzilla
« Reply #18 on: January 28, 2006, 04:16 AM »
I had a nos pr. of z rims that were warped....I tried the freezing with no success. I then boiled the rims and formed them back into their natural state. I also weighted them down for a couple of days. After assy. the spin nice and true. Good luck.
