976302 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 01, 2026, 10:28 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  fitting headset and BB
Author Topic: fitting headset and BB  (Read 1724 times)
karlos100
« on: December 06, 2008, 10:16 AM »
Whats the easiest way? I fitted a headset at work using a press and bits of wood but thought it must be easier another way as the cups kept on going on the pizzz as was pressing them in. I used a small film of grease to aid them in too but it took two of us 15-20 mins to eventually get the buggers in. i heard of people using wood and hammers etc but dont wanna be wreckin a frame after over 20 years sat in its box  :idiot2:
thecrooch
Re: fitting headset and BB
« Reply #1 on: December 06, 2008, 10:45 AM »
a press is always the best way - you can buy a cheap enough tool to do it.  they always look like they will go in on the pizz but end up sorting themselves out in the end
as for BB's i find if you use a press you can squash the bearings so best use a rubber mallet and wood
mr.magoo
« Reply #2 on: December 06, 2008, 07:02 PM »
Just like getting 'em out, i have no patience, rubber mallet and wood, if i'm feeling good, if not just the mallet :LolLolLolLol:
Juju
« Reply #3 on: December 06, 2008, 07:13 PM »
I was on youtube some guy made his own press's out of a couple of big washers and a bottom bracket spindle.
Bolted one washer tightly to the spindle using a couple of nuts, then the other washer is tightened by a nut to actually press the shells in.
Looked easy to me.
TorkerJones
« Reply #4 on: December 06, 2008, 07:51 PM »
I used a wooden mallet on my Torker restoration - using a wooden workbench to rest the bike on.  Friction surfaces all seemed clean and it went together a treat.
I'm just trying to decide what grease to use now.  I have some comma car grease, but thought better.  I'm off to Halfrauds in the morning to get some finish line synthetic grease - it seems well recommended.
mr.magoo
« Reply #5 on: December 06, 2008, 07:57 PM »
yeah but not cheap, bitd my dad used to bring me home big tubs of machine grease from his factory, now i use lythium? grease from halfrauds, but wow...i did not know it was so costly... when that runs out i'm reverting back to cheap... something like
cant believe its not butter :LolLolLolLol:
Goose1
« Reply #6 on: December 06, 2008, 08:15 PM »
I knocked this up at work.Bit industrial I know but it's perfect for both jobs :daumenhoch:
Offline brass monkey!
« Reply #7 on: December 06, 2008, 08:20 PM »
wood 'n' mallet  ;)
karlos100
« Reply #8 on: December 06, 2008, 08:25 PM »
thought about makin something similar but being a frikkin perfectionist i didnt want to leave any marks on the headset as its black to match the frame. shame when i unravelled the frame it was scratched anyway and needs touchin up in a couple of places. tut! next week im pressing a chrome tange one into my other frame. i think that will go bit better...hopefully!
mr.magoo
« Reply #9 on: December 06, 2008, 08:42 PM »
only frameset i've ever marked using just the mallet was a can spray painted one, works everytime for me, gently does it gently taps going round in circles to try to keep even as it goes in :daumenhoch:
