976295 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 20, 2026, 08:23 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  can brakes be converted?
Author Topic: can brakes be converted?  (Read 4772 times)
d14vd_h
« on: January 31, 2006, 01:01 AM »
does anyone know if its possible to convert a rear weinmann brake caliper to a front one easily?
and if so will they look/work the same?
Re: can brakes be converted?
« Reply #1 on: January 31, 2006, 08:32 AM »
yes mate just change the spindle
« Reply #2 on: January 31, 2006, 09:14 AM »
if that doesnt work sometimes a spell in jail will help them see god
Offline sawzall
« Reply #3 on: January 31, 2006, 09:15 AM »
 :2funny: :2funny: :2funny:
d14vd_h
« Reply #4 on: January 31, 2006, 04:04 PM »
nice one chaps any chance of a dummies guide?
 :uglystupid2: i need a bolt by bolt run through
Offline ORB
« Reply #5 on: January 31, 2006, 04:19 PM »
there is only one bolt!
12
« Reply #6 on: January 31, 2006, 04:33 PM »
hehe
just undo it
swap the spindle
rebuilding is a reversal of stripping
d14vd_h
« Reply #7 on: January 31, 2006, 05:10 PM »
i know told u it was a dummies guide, im seein two bolts? one in the centre of the caliper the other holing the arm on ,
any chance of a picture guide?  :-\ :laugh: :-[
cheers
« Reply #8 on: January 31, 2006, 06:28 PM »
just put the parts you take off in a line.
then change the spindle.
and put the parts back on in reverse to how you took em off.
Offline Rombloke
  • do one
« Reply #9 on: January 31, 2006, 07:24 PM »
fookin hell dude....lol
your best bet is to put all the bits in a bag...jumble em up, then put em back together in any old order
......picaso style brakes
Dave
haro, how do you do
d14vd_h
« Reply #10 on: January 31, 2006, 08:34 PM »
ok heres the pic of the actual caliper that will be used,
if u guys could explain using this thatd be great,
i think in my head i think this is a more complex job than it is as ive never done it before!
[attachment deleted by admin]
Offline ORB
« Reply #11 on: February 01, 2006, 11:08 AM »
Take the Acorn nut off the end
Take the normal nut off
Take the washer off
Take the front arm off
Take the washer off
Take the rear arm off
Take the washer off
Take the spring out
Put new spring in new Spindle
Put washer on
Put rear arm on
Put washer on
Put front arm on
Put washer on
Put flat nut on and nip up so there is no play and arms move freely
Hold back nut in place with a spanner and Nip up the Acorn nut against it
Done
12
« Reply #12 on: February 01, 2006, 11:13 AM »
 :4_17_5:
« Reply #13 on: February 01, 2006, 11:13 AM »
add some salt too
gmac
« Reply #14 on: February 01, 2006, 11:16 AM »
 :2funny:
« Reply #15 on: February 01, 2006, 11:21 AM »
« Reply #16 on: February 01, 2006, 12:46 PM »
well how did it go?
« Reply #17 on: February 01, 2006, 02:31 PM »
surely nothing went wrong
« Reply #18 on: February 01, 2006, 02:32 PM »
i reckon he used to much salt
Offline ORB
« Reply #19 on: February 01, 2006, 02:34 PM »
Maybe the water was not hot enough to desolve the salt?
12
« Reply #20 on: February 01, 2006, 02:35 PM »
and, of course it can only contain so much salt before it is at its capacity.
Offline ORB
« Reply #21 on: February 01, 2006, 02:38 PM »
so, maybe not enough water to desolve the salt?
Hmmm
gets a bit complex if you start thinking about it.
12
« Reply #22 on: February 01, 2006, 02:40 PM »
he knew that, thats why he asked for a step by step guide. and look what happened.
« Reply #23 on: February 01, 2006, 02:40 PM »
im gonna do a powerpoint presentation.
« Reply #24 on: February 01, 2006, 03:18 PM »
you lot have salt on the brain  :D.
