976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 02, 2026, 09:14 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  super tight freewheel!
Author Topic: super tight freewheel!  (Read 1773 times)
telelogic
« on: December 19, 2008, 01:08 PM »
Hi chaps,
trying to get a freewheel off of a mates rear tuff.
putting an amazing amount of torque through the thing and it just won't budge. :yahoo_silent:
maybe we are turning it the wrong way?
do they come of in pedal forward direction or pedal back?
cheers.
moley
Re: super tight freewheel!
« Reply #1 on: December 19, 2008, 01:13 PM »
A freewheel tightens as you pedal!!!
So the opposite will loosen it!  :daumenhoch:
Leverage is the key!!
I use a long lever and then twat it with a lump hammer!!  :daumenhoch:
Offline phantom photon
« Reply #2 on: December 19, 2008, 01:13 PM »
Whichever way the freewheel spins freely is the way you have to unscrew it  :daumenhoch:
moley
« Reply #3 on: December 19, 2008, 01:18 PM »
HEYWOOD BMX
« Reply #4 on: December 19, 2008, 01:31 PM »
 :) It used to be called anti-clockwise when I were a lad!
moley
« Reply #5 on: December 19, 2008, 01:38 PM »
thecrooch
« Reply #6 on: December 19, 2008, 01:40 PM »
put it in a vice, leave the tyre on for grip - left turn clyde!!!
« Reply #7 on: December 19, 2008, 01:40 PM »
-Put the freewheel tool on the freewheel, and hold it in place with the wheel nut.
-Put the TOOL in a vice and turn the wheel, like you were driving a bus.
This is THE best way to remove a freewheel. Works even better if you have a nice fat tyre on there for extra leverage.
(Note: make sure that once the freewheel is "cracked" and has started moving, you stop and take of the wheelnut. It wont come off very far with it on there)
« Reply #8 on: December 19, 2008, 01:41 PM »
Or ... like he said  :daumenhoch:  :LolLolLolLol:
thecrooch
« Reply #9 on: December 19, 2008, 01:44 PM »
ha ha sorry Alex - i like your version as well... nicely put.... ha ha
moley
« Reply #10 on: December 19, 2008, 01:57 PM »
Do you need a Orangutan to assist!!
Because I'm all out of them!!  :(
« Reply #11 on: December 19, 2008, 03:42 PM »
Always consider a good LBS  ;)
JT71
« Reply #12 on: December 19, 2008, 04:01 PM »
remember if you are using a left hand drive system, s&M Alex tm,  (which you almost certainly won't be on a tuff) you'll need to "right turn clyde"
