976302 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 02, 2026, 11:30 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  convert front mag to a rear?
Author Topic: convert front mag to a rear?  (Read 1716 times)
Mr Nice
« on: January 09, 2009, 06:40 PM »
Is it possible? local bike shop has two unbranded front mag wheels and was wondering if i could convert one to a rear
adeshere
Re: convert front mag to a rear?
« Reply #1 on: January 12, 2009, 10:42 PM »
If they are anything like Tuff's then you cant.
The front wil just have the axle, where the rear would have a coaster or an area to attach a freewheel
« Reply #2 on: January 12, 2009, 10:54 PM »
Alloy hubbed tuffs can be done if you have a good engineer.
Voodoocars
« Reply #3 on: January 13, 2009, 07:10 PM »
I used to have a tuff wheel that had bolts holding the hub in place instead of rivets and I used to swap between a freewheel and a coaster hub.
JT71
« Reply #4 on: January 14, 2009, 02:39 PM »
if these are shiney black or white five spoke mags steer well clear, seen some of these and flex a sh1t load if you put any sort of weight on them
adeshere
« Reply #5 on: January 14, 2009, 06:56 PM »
If they are tuffs with plastic hubs then you can't  but if they are the metal hubbed type then you probably can
« Reply #6 on: January 14, 2009, 08:51 PM »
Probably?
« Reply #7 on: January 15, 2009, 07:24 AM »
my guess is that if they are unbranded mags, then they will be cheap and flexy fookers and more trouble and expense than it'll be worth to convert them.
just buy a new set of tuffs for about £60 if you want some for a rider?
Mr Nice
« Reply #8 on: January 15, 2009, 06:52 PM »
cheers everyone. think i'll sack that idea then
