976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 03, 2026, 02:08 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Pro Class 3 Rims NOW WITH PHOTO'S
Author Topic: Pro Class 3 Rims NOW WITH PHOTO'S  (Read 3478 times)
Offline Peter J
  • I have issues
« on: January 26, 2009, 09:24 PM »
Anyone know of any way to remove the Hard Ano off them. Apart from taking then to a plater to remove it.
I've tried:
Media Blasting. Will work but just worried its a bit harsh
Oven Pride.........pointless
« Last Edit: January 28, 2009, 08:58 PM by Peter J »
Re: Pro Class 3 Rims
« Reply #1 on: January 26, 2009, 09:29 PM »
 :shocked: :shocked:
Why d'ya wanna do that mate ? Must be proper fooked to do that to e'm !
Can't you shine side them with some wet n dry and leave the inside of the rim hard ano ?  ???
Offline Peter J
  • I have issues
« Reply #2 on: January 26, 2009, 09:34 PM »
Yep anno is flaking, and some goon has started to remove the anno and given up so they look a complete pig.....at the moment
Daletsunami
« Reply #3 on: January 26, 2009, 09:36 PM »
Oven pride worked fine with mine, came off easy and have now polished up great  :smitten:
Offline Peter J
  • I have issues
« Reply #4 on: January 26, 2009, 09:45 PM »
How long did you leave it in the bag for ?
Daletsunami
« Reply #5 on: January 26, 2009, 09:49 PM »
Was about 10 mins each rim, but constantly kept them turning in the thick of the oven pride and using my thumbs to rub it in.
Offline Peter J
  • I have issues
« Reply #6 on: January 26, 2009, 09:49 PM »
Ok I'll give that another bash.....  :daumenhoch:
Offline Peter J
  • I have issues
« Reply #7 on: January 26, 2009, 10:05 PM »
Just tried the oven pride again and no joy................think they might be chrome plated  :-\
TBH its hard to tell..................think I'll take it to a plater to find out  ???
steve Beech TA
« Reply #8 on: January 26, 2009, 10:45 PM »
Try some gasket remover, spray it on and give them a little scrub with a tooth brush, i used my wife's :daumenhoch:
Offline sawzall
« Reply #9 on: January 27, 2009, 05:55 PM »
i used caustic soda,they took about half an hour but keep checking every couple of mins,i also used a scotch brite pad to help remove it,the hard anno is a real bitch to remove >:(
login_user
« Reply #10 on: January 27, 2009, 08:18 PM »
i used oven pride on my hard annod rims but tou have to scrub them with a brillo pad like sawzall said  :daumenhoch:
neiljonarcus
« Reply #11 on: January 27, 2009, 08:30 PM »
caustic  soda  thats  what i use  for  anadizzzzzzed stuff  it  works  a treat
« Reply #12 on: January 27, 2009, 08:34 PM »
I had a real bad time with my Pro cass 3's
Oven brite in the bag
kept going back to them every 10 mins for about 40 mins , nothing happening hardly
so left them for about another 40 mins , patchy as hell still ano on in parts and just started to pit  away at the rims
,,, gutted to say the least as these rims only had minimal brake rub on the rear only and front was like NOS  :crazy2:
I'd advise you to agitate it as much as possible  wih a brillo or equivelant
rather than let any type of acid do the work as the coating really is unbelievably hard  on the Pro class 3 's  :-\
« Reply #13 on: January 27, 2009, 08:35 PM »
Normal anno comes off in upto 15 mins
this stuff doesn't  :(
Offline Peter J
  • I have issues
« Reply #14 on: January 28, 2009, 02:22 PM »
Ok chaps...........I'll give it another bash............oven pride bag here I come !!!!!!!
« Reply #15 on: January 28, 2009, 02:50 PM »
Get some pics up mate - you know we're all voyeurs on here  :LolLolLolLol:
Offline Peter J
  • I have issues
Re: Pro Class 3 Rims (Now with Pictures)
« Reply #16 on: January 28, 2009, 03:18 PM »
I'll get my fat fingers on the case tonight  :daumenhoch:
I'll put some special pictures on tonight  :D
« Last Edit: January 28, 2009, 08:41 PM by Peter J »
Offline Peter J
  • I have issues
« Reply #17 on: January 28, 2009, 08:46 PM »
So I've tried the Oven Pride trick again..left em for 20 min.......scotch brite rub down. in total they had 4 x rub downs and 120 mins in the bag.........didnt touch them.........
Any Idea's
I've not touched this one yet....
This one's had the oven pride on it........
The Matt looking bits in the middle are where its flaked off..........oven pride did................foooooooooook all  :knuppel2:
« Last Edit: January 28, 2009, 08:49 PM by Peter J »
Re: Pro Class 3 Rims NOW WITH PHOTO'S
« Reply #18 on: January 28, 2009, 09:15 PM »
Blast 'em  :2gunsfiring_v1:
etriedes
« Reply #19 on: January 29, 2009, 04:14 PM »
have you tried caustic soda #?
« Reply #20 on: January 29, 2009, 05:24 PM »
I would try caustic , keep an eye on them though ! .
Offline jT Racing
  • i like bikes. :/
« Reply #21 on: January 29, 2009, 05:39 PM »
120 minuted in the costic and the y will be proclass superlite 1 1/8 sideless. be carefull with the stuff and do it outdoors. 5 mintues tops or they will get melted. works every time though.
ding dong
Offline Peter J
  • I have issues
« Reply #22 on: January 29, 2009, 06:30 PM »
No not tried the Caustic approach  :shocked:
I'll give it a bash at the weekend...
I took them into work today and started media blasting.......................bugger that it will take forever !!!
Offline Glynnyboy
« Reply #23 on: January 30, 2009, 07:40 PM »
If your not totally sure i would have a word with paul or mark at cca. It seems they were withdrawing there services just before christmas. They may have reconsidered from what i gather now.
I went over to take some stuff a few month ago and paul showd us the whole set up. We got talking about possibilites. Hard anno in particular, he said hard anno is a lot more resistant to wear than normal which is why your haveing trouble. Seems it actually strengthens the item which is probably why they started using it on the proclass :daumenhoch:
Offline Peter J
  • I have issues
« Reply #24 on: January 30, 2009, 08:21 PM »
No joy with the caustic......  :'(
Looks like a trip to the platers
